Haibike eConnect
Kimmoi
391
385
Finland
Is it only for Haibike or is it possibly use with other bikes too?
Is it powered by motor output, and if so what are the Voltage/current demands?
And where can i buy one? :)
Just asking because there's not many good gps- tracking options for thieves. :sneaky:
So, is it possibly use eConnect with other bike brands too?
Thomas B.
10
7
Metten17!
I used to have a Haibike Hardnine with Yamaha PWX and aftermarket eConnect. I had to return my bike after a year for 90% refund, but needed to keep my eConnect. Now i tried how to run it on my new Specialized with Brose 1.3 Motor. The eConnect Cable is hooked into the Display Cable of the Yamaha, but I figured out that red and black are the „power“ cables. I tried to charge external with a power supply and the unit draw at max. 300mA at 6.2Vdc. So i was able to stip down the wiring and attached it to the Brose light connector which is always powered. The only issue is, i do not know which „future“ updates or functions won‘t work. And you need a supported Haibike frame number to initially enable your eConnect account.
521K
