Hi.
During winter maintenance I intended to check and tighten the engine screws, so I took off the engine cover (in 2021 model 2 of 4 screws are hidden below the cover) and found the screw eyelet to be broken. The one below the charging port. Of course it was completely invisible under the cover.
The complete frame has been already replaced by LBS based on the warranty and everything is fine now but the reason for posting this is to make you aware of that possibility.
