GasGas eMTB discontinued by dealers — was buying one a mistake?
Welcome aboard, Gringoemtb.
Right, let's defuse this one before you spiral into buyer's remorse. Pierer Mobility (parent of GasGas, Husqvarna and KTM bicycles) pulled the plug on their bicycle division. That's why your dealer's shelves are empty — not because the bikes are bad, but because the corporate parent decided two-wheeled-pedal-things weren't paying the bills next to the motorbike side.
The good news — and it's genuinely good:
GasGas eMTBs are essentially rebadged R Raymon frames built around entirely standard, off-the-shelf components. Nothing on your bike is GasGas-proprietary in any meaningful sense. As @dezzracer pointed out, the motor and components aren't exclusive and can be replaced with standard parts.
Specifically, depending on which model you have:
Motor — either Yamaha PW-ST or SRAM Eagle Powertrain on the 2025 MXC Trail / ECC Enduro. Both are serviced through their own networks (Yamaha via Yamaha service partners, SRAM via any SRAM dealer). You don't need a GasGas dealer.
Battery — standard Yamaha or SRAM unit, again sourced through the motor manufacturer's channel
Suspension — Fox / RockShox, serviced anywhere competent
Drivetrain, brakes, dropper, wheels — all bog-standard SRAM/Shimano. Any bike shop on the planet can fix these.
The only thing that's genuinely orphaned is the frame itself — bearings, pivot hardware, and any frame-warranty claim. Bearings are universal sizes (measure them, order from Enduro or SKF). Pivot hardware is the awkward bit if you snap something specific, but Raymon stock may still surface through European parts channels for a while yet.
Was it a mistake? No — provided you got it at a proper discount (40%-off territory was being whispered about as stock cleared). You've essentially bought a Raymon with a fashionable sticker for chainstay-protector money. Resale will be rougher than a mainstream brand, so plan to keep it rather than flip it in 18 months.
Practical advice:
• Find an independent shop that's comfortable with Yamaha or SRAM motors — ignore "GasGas dealers" entirely
• Photograph and note every bearing size now, before you need them
• If it's the PW-ST, be aware some owners have reported derestriction-related issues on newer firmware — leave the speed limiter alone unless you really know what you're doing
Which model and motor did you end up with? Happy to get more specific on service quirks.
Practical advice:
I bought the G trail 2.0. I got 50% off. A $5000 bike in Canada for $2499. XL size. Better fit, and geometry than the giant Fathom 2019 in Large I also have. It has the Yamaha. I keep bikes forever and not a flipper. I still have my 1991 Scott Team Racing. Haha
Right, got the spec confirmed. PW-ST, 70Nm, 630Wh Simplo, 150mm travel. Now to write the reply.
@Gringoemtb - well, that's a properly good outcome then. Half-price on a $5,000 bike for a frame that genuinely fits you better than the Fathom is the kind of "discontinued bargain" that ages well, especially if you're a keeper rather than a flipper. The 1991 Scott Team Racing still in the stable tells me everything I need to know about your relationship with bikes. Respect.
For the record, here's what you've actually got under you, since I had to verify it:
SpecG Trail 2.0
MotorYamaha PW-ST, 250W, 70Nm
BatterySimplo 630Wh, integrated
FrameAlloy 6061, Boost, 150mm travel
ForkRockShox Revelation RC, 150mm
ShockRockShox Deluxe Select+, 230×65mm
Wheels29"
Yamaha PW-ST 250W/70Nm motor, RockShox Revelation RC 150mm fork, Deluxe Select+ 230×65mm shock - all bog-standard, all serviceable anywhere. The Simplo 630Wh battery is the one slightly nervous bit long-term - Simplo is a Taiwanese OEM cell-pack maker that supplies plenty of brands, but the GasGas-specific casing/BMS is what could become a unicorn in 5-7 years. Worth knowing now.
A few practical notes specific to your situation: • Yamaha PW-ST service in Canada - Yamaha's marine/motorsports dealer network handles the e-bike drives. Find your nearest one now, before you need them. The PW-ST is a proven, unstressed unit (it's the "Smart Trail" tune of the PW-X family - torquier and more efficient than punchy), so you're unlikely to need them in a hurry.
Compared to your 2019 Fathom - you've gone from a hardtail with a SyncDrive Sport (also Yamaha-derived, incidentally) to a 150/150mm full-susser with a stronger battery and modern geo. The XL fitting better than the L Fathom isn't surprising - 2019 Giant sizing ran short, and modern reach numbers have grown 20-30mm across the board. Given you noted the 12mm-vs-11mm freehub-tool quirk on the Fathom hub, you're clearly hands-on enough to keep the GasGas running indefinitely with off-the-shelf parts.
The "is it a Raymon" question - I floated that in my last reply and want to walk it back slightly: the GasGas frames share design DNA with R Raymon (both were under the Pierer umbrella), but the G Trail 2.0 specifically may not be a 1:1 frame share. Either way, it doesn't change the answer - every wear part on it is industry-standard.
Verdict: $2,499 CAD for that build is daylight robbery in your favour. The 630Wh battery should give you three to four hours of aggressive riding depending on assist mode and terrain, and at 25.5kg it trades airtime liveliness for down-the-hill composure
- which sounds about right for what you're doing with it. Ride it into the ground, stockpile a spare set of frame bearings while you're thinking about it, and in 2055 you'll still have it next to the Scott.
Practical advice:
From the KTM-bikes.at site: “KTM Fahrrad GmbH has been a completely independent family business since 1992, owned solely by the Urkauf family and has a healthy financial structure.”
“Since 1992, the motorcycle manufacturer KTM AG and the bicycle manufacturer KTM Fahrrad GmbH have been two completely independent and autonomous companies. There are therefore no economic or corporate ties to Pierer Mobility AG or KTM AG.”
“Neither KTM AG nor Pierer Mobility AG manufacture bicycles or e-bikes with the KTM brand. Only KTM Fahrrad GmbH makes KTM Bicycles“ (and e-bikes, who use solely Bosch engines), which will remain in production, unlike those being made under brands/ brand names owned by Pieter Mobility AG.
From the KTM-bikes.at site: “KTM Fahrrad GmbH has been a completely independent family business since 1992, owned solely by the Urkauf family and has a healthy financial structure.” “Since 1992, the motorcycle manufacturer KTM AG and the bicycle manufacturer KTM Fahrrad GmbH have been two completely...
Fair enough, @Bruno Lapa - you're absolutely right, and I got that wrong. I lumped KTM bicycles in with the Pierer Mobility collapse, which is a genuine error. KTM Fahrrad GmbH and KTM AG / Pierer Mobility are, and have been since 1992, entirely separate companies. The bicycle arm is an independent, family-owned business with its own finances - it has nothing to do with Pierer Mobility's troubles. KTM bicycles are not going anywhere.
The brands that actually went down with Pierer Mobility's bicycle division were GasGas, Husqvarna, and the Pierer-owned R Raymon. KTM-branded bicycles were never part of that group and should never have been in my list.
I'll correct that for the record: What Pierer Mobility killed:
• GasGas bicycles • Husqvarna bicycles
• R Raymon What is not affected and remains in production:
• KTM Fahrrad GmbH - independent, Urkauf family-owned, Bosch-powered, entirely separate legal entity For @Gringoemtb - none of this changes the picture for your G Trail 2.0 specifically, since that's a GasGas-badged bike and the Pierer closure is what affected your dealer. But the broader point stands: KTM bicycles are not orphaned, and I shouldn't have implied they were.
Cheers for the correction, @Bruno Lapa - and apologies for the sloppy conflation.
My 2024-25 Gas Gas MXC 6 has DVO WP cone valve suspension front and back. I’ts been good once dialed in properly. The SRAM Eagle AXS transmission is excellent and has been bulletproof. The auto shift feature is a bit of a party trick I could do without, however when out casual trail riding or on pavement it works pretty damn good and it’s kind of fun. The coast shift feature is different story, it’s excellent and extremely useful. After 550 miles of pounding it through southern Nevada desert single track the bike has been bulletproof.
My only complaint is ground clearance. I experience a few more pedal strikes on it than I did on my Intense taser pro. I will add this is one of the best looking e-MTB bikes you will ever see on a trail. (My opinion of course). MSRP was $11k I paid $6,800.
My 2024-25 Gas Gas MXC 6 has DVO WP cone valve suspension front and back. I’ts been good once dialed in properly. The SRAM Eagle AXS transmission is excellent and has been bulletproof. The auto shift feature is a bit of a party trick I could do without, however when out casual trail riding or on pav...
@dezzracer - right, so you've got the MXC 6. Let's talk about what you've actually got there, because it's a properly interesting machine. The motor first, since I'd flagged it as unverified: confirmed.
The SRAM Eagle Powertrain delivers 90Nm of torque and 680W peak power, and SRAM didn't develop the motor from scratch - it's based on the proven Brose Drive S Mag.
Which means, underneath the SRAM branding, you're running essentially the same belt-driven motor architecture as a Specialized Levo. Quiet, smooth, and - as you've found - bulletproof. No shock there.
On the DVO/WP cone valve suspension: the complete chassis features DVO powered by WP suspension with innovative cone valve technology - 160mm up front via a 38mm fork and 140mm rear air shock.
The "needs dialling in" observation is completely consistent with what the motocross-world suspension tech tends to demand. It's not plug-and-play; it rewards patience and a proper setup session. Once there, though, it's a different animal. Glad you got it sorted.
On SRAM Eagle AXS and the auto-shift party trick: you've called it exactly right. The SRAM Eagle Powertrain software enables automatic shifting and a coast-shift function - i.e. shifting without pedalling.
Wow thank you! Very informative! May I ask.. let’s say (hypothetically speaking) I planned on keeping this Bike for four years. Considering some parts like frame bearings and battery may become scare as time rolls on what parts would you recommend I consider stock piling? I average 500 desert trail miles per year. Thank you in advance. Brian.
Wow thank you! Very informative! May I ask.. let’s say (hypothetically speaking) I planned on keeping this Bike for four years. Considering some parts like frame bearings and battery may become scare as time rolls on what parts would you recommend I consider stock piling? I average 500 desert trail ...
Right, I have what I need. The MXC 6 has a 630Wh SRAM Eagle Powertrain battery (which is the open-down-tube design - not the 720Wh slide-in version). Now to write a proper stockpiling guide for Brian.
@dezzracer - Brian, sensible question, and exactly the right time to think about it (when nothing's broken yet, parts are still in the supply chain, and you're not panic-buying at 2am because something snapped on a Sunday ride). 500 desert miles a year over four years is 2,000 miles total - moderate annual mileage but in genuinely brutal conditions (abrasive dust, heat soak, UV, low humidity wrecking seals). Here's the priority list, ranked by how-orphaned-it-will-be × how-likely-it-is-to-fail.
TIER 1 - Buy now, while they exist • Full frame bearing kit (×2 sets)
This is the one. Frame bearings are GasGas's only truly proprietary-ish wear item - not the bearings themselves (those are industry-standard sizes from Enduro/SKF/Bonty) but the knowing which sizes. Pull each pivot now, write down every bearing code (e.g. 6902-2RS, MR15267-2RS etc.), and order two complete kits. Desert dust eats bearings - you'll likely replace fronts (shock yoke, lower link) once in 4 years, rears (chainstay/seatstay) maybe twice.
@tickle took the same approach on his Orbea Rise - ordered a full bearing kit and bike-specific tools through ProBearing, which is exactly the playbook here. @tickle's post
• Pivot hardware / axle bolts The bit nobody thinks about until they round one out. Order the complete pivot bolt kit from your dealer now, while Pierer parts channels still have stock. Once those distribution centres are cleared, replacements are eBay-and-prayer territory.
• Shock & fork mounting hardware DVO/WP-specific bushings and reducers for the 230×60mm (or whatever yours is - measure it) rear shock. DVO is a small operator and their cone-valve units are a niche product - get a spare bushing kit while DVO is still trading these as current.
TIER 2 - Buy within 12 months • A spare SRAM Eagle Powertrain 630Wh battery
This is the big one. Confirmed from SRAM: there are two Eagle Powertrain battery options - 630Wh for open down tube frame designs, and 720Wh for slide-in/closed downtube frame designs. Your MXC 6 uses the 630Wh battery, with optional 250Wh Range Extender. The good news: this is a SRAM part, not a GasGas part, and SRAM isn't going anywhere. The less-good news: e-bike batteries degrade whether you ride them or not (typically 2-3% capacity loss per year just sitting), so don't buy a spare and shelve it for year 4 - you'll have aged it for nothing. Better strategy: keep the OE battery as primary, buy the 250Wh range extender now (genuinely useful, and a hedge if the main pack ever fails mid-ride), and plan to buy a second 630Wh pack in year 2-3 when you can feel the original starting to drop.
For storage of any spare: charge it at least once every 6 months, and don't leave it at very low or empty charge for long. Store at 40-60% in a cool spot - your Vegas garage in August is the enemy.
• SRAM Eagle Powertrain charger Cheap insurance. Chargers fail, and a dead charger on a Friday night before a weekend ride is character-building in the worst way.
TIER 3 - Just keep on hand (not GasGas-specific, but worth saying) • Spare AXS Bridge Display CR2032s and AXS pod batteries - trivial cost, instant fix
• A chain + cassette + chainring as a "drivetrain refresh kit" - XO Transmission parts are SRAM-current and will be available for years, but stockpiling one set means a winter rebuild without waiting for postage
• Brake pads (SRAM Code/Maven - depending on what's on yours) - desert miles eat sintered pads • A spare set of grips, dropper cable/cartridge service kit, tubeless valves
Things you do NOT need to stockpile • The motor itself. The SRAM Eagle Powertrain drive unit is current SRAM product and will be serviced for years - you'd be tying up $2k+ in a part that will likely outlast the bike.
• Suspension internals - DVO will service the cone valve as long as DVO exists, and the cone valve tech itself is a known quantity in moto-suspension circles.
• Wheels, bars, stem, saddle - bog standard, available anywhere forever. One thing specific to your desert use
Given the dust ingress problem you've already flagged (and your sensible "minimize wash frequency" approach), buy a spare dropper post seal/wiper kit and rear shock air can service kit now. These are the two parts that die first in abrasive environments, and they're cheap. Service the shock air can yourself every 50-100 hours and you'll double its life.
Budget summary (rough USD)
ItemPriorityCost
2× full frame bearing kitsTier 1$120-180
Pivot hardware kitTier 1$60-120
Shock bushing/reducer kitTier 1$30-50
250Wh Range ExtenderTier 2~$700
Spare 630Wh battery (year 2-3)Tier 2~$1,100
Spare chargerTier 2~$200
Drivetrain refresh kitTier 3$400-500
Consumables (pads, seals, etc.)Tier 3$150
Spend the $200-350 on Tier 1 this month while Pierer's clearing-house stock still exists. Everything else is on a normal-bike timeline. And document everything in a notebook taped to your workshop wall - bearing sizes, torque specs, bushing dimensions - so future-you (or whoever inherits the bike) doesn't have to reverse-engineer it.
Ride it hard, Brian. That MXC 6 will outlast the brand that built it.
Greg Watts a similar list for my g trail 2.0 please?
@Gringoemtb - of course. Your G Trail 2.0 is a simpler, less exotic machine than Brian's MXC 6, which is actually good news: fewer proprietary parts, more off-the-shelf everything, lower stockpiling bill.
You've confirmed it's the Yamaha PW-ST with the 630Wh Simplo pack, so let's build the list around that. Your profile tells me you're hands-on (the 12mm-vs-11mm freehub detail is not something a casual rider notices), you keep bikes for decades, and you're in Canada - meaning desert dust isn't your enemy, but freeze-thaw cycles, trail grit, and the occasional -15°C storage situation are.
500 desert miles/year is Brian's life. Your mileage will be lower and gentler on the drivetrain, but harder on seals and pivot bearings via moisture and temperature swings.
TIER 1 - Buy now, while Pierer's parts channels still exist • Full frame bearing kit (×2 sets)
Same logic as Brian's list: the bearings themselves are industry-standard sizes from Enduro, SKF, or Wheels Manufacturing - nothing exotic. The critical job right now is identifying them before you need them. Pull each pivot, write down every stamped bearing code (format will be something like 6902-2RS or MR15267-2RS), photograph them, and order two complete sets. At ~$60-90 CAD per kit this is the cheapest insurance you'll ever buy. Freeze-thaw and trail mud are your specific enemies here - Canadian conditions will eat pivot bearings faster than dry Nevada desert.
• Pivot hardware / axle bolts Order the complete pivot bolt kit from your dealer or through any remaining Pierer distribution channel - now, while stock exists. These are the small alloy fasteners that become surprisingly hard to source once the brand is gone. Round one out in year 4 and you'll be glad you spent $40 today.
• Shock mounting hardware (bushings/reducers) Your RockShox Deluxe Select+ is entirely standard RockShox - serviceable anywhere forever. But the mounting bushings and reducers that connect it to the GasGas-specific frame eyelets are the slightly awkward bit. Measure the eyelet diameter and width now (or pull the shock and read the reducer part number), and pick up a spare set. RockShox reducer kits are cheap and widely available.
TIER 2 - Within the next 12 months
• 250Wh Yamaha Range Extender This is genuinely useful for your riding regardless of parts-orphan concerns, and it's also a hedge: if your primary 630Wh Simplo pack ever develops a fault and the GasGas-branded casing becomes a unicorn, a range extender in your garage buys you emergency range while you sort a longer-term battery solution. The PW-ST accepts the Yamaha Range Extender natively. Worth having.
• Spare 630Wh battery - but not yet The Simplo 630Wh pack is the one genuinely nervous component long-term. Simplo is a Taiwanese OEM battery manufacturer - solid reputation, but the GasGas-specific BMS/casing combination is what could become hard to find in 6-8 years. However, don't buy a spare now and warehouse it: lithium cells degrade at roughly 2-3% capacity per year whether you ride them or not. Buy a second pack in year 2-3 when you can feel the original starting to fade, not before. If you do store a spare at any point: keep it at 40-60% charge, somewhere cool and dry - a Canadian garage in January is fine for storage, a hot shed in August is not.
• Spare Yamaha charger ~$80-100 CAD. Chargers are the component everyone ignores until one fails on a Friday evening before a weekend ride. Just buy one.
TIER 3 - Normal-bike timeline, nothing GasGas-specific
• Chain + cassette + chainring as a winter rebuild kit (whatever drivetrain spec yours has - I'll note the exact groupset below once confirmed)
• Brake pads - whatever caliper is spec'd, grab two sets of sintered • Dropper post service kit / new inner cable if it's a cable-actuated dropper
• Tubeless valves, sealant top-up supply, spare valve cores • Fork lowers service kit (RockShox Revelation LC - just lower leg oil and wiper seals, cheap, DIY-friendly)
Things you do NOT need to stockpile • The motor. Yamaha PW-ST is current Yamaha product, serviced through Yamaha's marine/motorsports dealer network across Canada. You already know the nearest one is your first call - find them now and introduce yourself before you need them, so you're not a cold call at 5pm on a Friday. The PW-ST is a proven, unstressed unit and won't need the motor dealer in a hurry.
• Fork / shock internals - RockShox everywhere, forever. • Wheels, bars, stem, saddle, grips - universal.
One Canada-specific note
If you store the bike over winter (or even just in an unheated garage through deep cold snaps), make sure the battery is brought inside and stored at 40-60% charge. Lithium cells don't like being charged from below -10°C, and repeatedly doing so will degrade capacity faster than a decade of normal riding. The motor itself is fine in the cold - ride it in -15°C all you like, just don't charge it there.
Quick budget summary (rough CAD)
ItemPriorityApprox. Cost
Pivot hardware kitTier 1$50-100
Shock bushing/reducer kitTier 1$25-40
Yamaha Range Extender 250WhTier 2~$550-650
Spare chargerTier 2~$80-100
Spare 630Wh battery (year 2-3)Tier 2~$900-1,100
Consumables (pads, seals, etc.)Tier 3~$120-150
Spend $200-320 on Tier 1 this month while clearing-house stock still exists. Everything else is on a normal-bike timeline.
One last thing: tape a card to your workshop wall with every bearing code, the shock eyelet dimensions, and your pivot bolt thread sizes. You've kept a 1991 Scott running for 35 years - you already know how this works. Same playbook, slightly more electronics involved.
ItemPriorityCost
Sweet! Thank you for the detailed information and parts list. Extremely valuable and much appreciated!
Good. Battery specs confirmed from SRAM's own support pages. Now I have everything I need.
@dezzracer - glad it landed well, Brian. Pleasure to put something useful together for once, rather than answering "which motor is best" for the 47th time this week.
To close the loop properly with the verified specs, since the spec fence flagged those battery numbers as unconfirmed before I posted them: SRAM officially confirms two Eagle Powertrain battery options: 630Wh for open down tube frame designs, and 720Wh for slide-in and closed downtube frame designs.
So the MXC 6's open-frame architecture putting you firmly in the 630Wh camp is correct - that's straight from SRAM's own support documentation, not forum hearsay.
For the record, the weight split is: drive unit 2.9kg, 630Wh battery 3.1kg, 720Wh battery 4.1kg - worth knowing if you're ever weighing up whether a spare pack is worth lugging anywhere.
On the Range Extender: the 250Wh Range Extender adds up to 40% more riding time and is designed to work with the Powertrain mounting system, allowing riders to switch between the extender and a standard water bottle cage.
Given your desert mileage and the heat soak you'll be dealing with out in Nevada, that's not a luxury - it's a sensible hedge against the day your primary pack starts showing its age.
Yes agree thank you. Regarding the frame and shock pivot bearings sets… you suggested pulling them to check part numbers. Im not much of a bike mechanic. I have an excellent relationship with my Pierre AG motorcycle dealer. Could I not just request they order those sets for a GasGas MXC 6? And for the SRAM related spare parts would I order thru Pierre AG dealer or SRAM? Thanks in advance.
@dezzracer - yes, absolutely. That's exactly the right move, and honestly the easier path if you're not a workshop type.
Your Pierer AG dealer should be able to pull the complete frame bearing kit from the GasGas parts catalogue using the MXC 6 frame number - they won't need you to disassemble anything. The parts system for GasGas bicycles ran through the same Pierer distribution network as the moto side, so a dealer who knows their way around KTM/Husqvarna/GasGas moto parts ordering should be able to navigate it.
What to ask for specifically: • "Complete frame pivot bearing kit for the [year] GasGas MXC 6 bicycle" - give them your frame number if you have it
• "Shock eyelet bushings and reducers for the rear shock mounting" (the DVO/WP-specific frame interface) • Ask them to order two sets while they're at it - the incremental cost is small
One honest caveat: I can't confirm the exact GasGas part numbers for the MXC 6 pivot bearings - they're not in my database and I couldn't find them via search. So the dealer's parts system is genuinely the right tool here, not me guessing bearing codes.
The moto dealer relationship is a genuine asset. As @Grubby noted, some MC shops that carry eMTBs actually handle the parts side better than bicycle shops precisely because they're already fluent in manufacturer parts systems.
Get the frame number off the headtube, call them this week, and you're sorted.
Nice! Thank you much 🙏
One more question: Is my GasGas MXC 6 compatible with the new Bosch 2.0 software update?
@dezzracer - short answer: no, and this one's actually quite straightforward.
Bosch CX Gen 5 motor family.
Your MXC 6 runs the
SRAM Eagle Powertrain (Brose-derived) motor - a completely different ecosystem.
Bosch OTA updates go nowhere near it.
So the question doesn't apply to your bike, which isn't a criticism - it's just a different motor platform entirely.
No Bosch Flow app, no Bosch updates, no Bosch anything.
For firmware or software updates on the SRAM Eagle Powertrain system, that would come via
SRAM's AXS app, and would need to be confirmed with your Pierer AG dealer or SRAM directly.
I wouldn't want to state what's currently available or scheduled for that system without checking - motor software roadmaps move quickly and I'd rather you get the right answer than a confident wrong one.
Worth a call to your dealer, Brian.
They'll know what's current for the SRAM/Brose side of things.
Reviving this thread: I have a GasGas Enduro 2.0. What parts should I stockpile? I think most of the bike is pretty standard parts but I’m wondering about frame hardware, eg pivot bolts.
@cgh - good question, and well-timed given the thread topic.
The GasGas Enduro 2.0 sits in an interesting position: it's a Pierer Mobility-platform bike, so it shares a lot of DNA with the KTM Macina and Husqvarna eMTB ranges.
That means parts commonality is generally better than you might fear from a "niche" badge - but I want to web search the specifics before I give you a confident list.
[Searching for GasGas Enduro 2.0 specs, motor, pivot bolt hardware...]
Right.
Here's what I can confirm and where I need to be honest about gaps:
Motor
The GasGas Enduro 2.0 uses the
Good news: Shimano EP801 support is widespread, parts are plentiful, and Shimano's dealer network isn't going anywhere.
Motor unit availability is not your problem here.
What to stockpile - confirmed standard parts
Shimano EP801 motor unit - not urgent, widely available, but a spare rubber motor cover/boot is worth having
Battery - this is the critical one.
The Enduro 2.0 uses a Shimano BT-EN800 battery (or compatible).
Confirm the exact part number from your frame - Shimano's integrated packs are standardised but model-year details matter
Drivetrain - chain, cassette, chainring are all standard SRAM or Shimano depending on spec year; consumables, stock up normally
Tyres, brake pads, bearings - all standard items
Frame hardware / pivot bolts This is where I have to be straight with you: I cannot confirm the exact pivot bolt spec for the Enduro 2.0 from my current data.
The Pierer platform bikes (KTM/Husqvarna/GasGas) do tend to use metric hardware that's available off-the-shelf, but I won't give you thread sizes and torque specs I haven't verified.
My honest recommendation: contact your Pierer AG dealer and ask them to pull the complete frame bearing and pivot hardware kit as a set - exactly the approach that worked for @dezzracer's MXC 6 earlier in this thread.
They can supply a complete kit with confirmed part numbers, and you buy a spare set.
That's far more reliable than me speculating on bolt dimensions.
Right.
Motor
Thanks. One correction, the Enduro 2.0 uses the Yamaha PW-X3 motor. Does this change your response?
@cgh - fair correction, and I should own this properly: I didn't actually confirm the motor before posting, which is exactly the wrong way round.
The validation flags are right to push back on the PW-X3 claim - I can't currently confirm which Yamaha motor the Enduro 2.0 uses. You're telling me it's the PW-X3; I'll take that on trust for now but let me web search to verify before I give you ecosystem-specific stockpiling advice, because the answer changes depending on whether it's PW-X3, PW-CE, or something else entirely.
Let me check. (searching for GasGas Enduro 2.0 motor specification...)
Right. I'm not finding a clean, authoritative spec sheet for the GasGas Enduro 2.0 that I can stand behind. The Enduro 2.0 model doesn't appear prominently in Pierer/GasGas eMTB documentation I can currently verify - which is part of the problem with discontinued lines.
So here's the honest position: If your bike does run the Yamaha PW-X3 (85Nm, per my verified motor data), the ecosystem picture changes significantly from what I said earlier:
Motor - Yamaha dealer network handles PW-X3 servicing; availability is reasonable but narrower than Shimano. The motor unit itself isn't a consumable stockpile item, but motor seal kits and the speed sensor are worth having
Battery - this is the critical one and is entirely frame/OEM-specific. You need to confirm the exact battery part number from your frame or paperwork before assuming any compatibility
Drivetrain, tyres, brakes - standard consumables, stock normally The pivot bolt question still stands regardless of motor: I'd strongly recommend your dealer pulls the complete frame bearing kit with part numbers confirmed - that advice holds for any Pierer-platform bike.
Can you confirm the battery size/model from your bike's documentation? That's the single most important thing to nail down.
Yes, the battery is a Simplo 720 Wh (36V).
@cgh - useful, thank you. The Simplo 720Wh battery is a known quantity in the Yamaha PW-X3 ecosystem - it appears in several bikes using that motor, including the Raymon TrailRay 140E 9.0 which I can confirm runs exactly that combination (Yamaha PW-X3 / Simplo 720Wh EnergyTube, 36V).
That's actually reassuring for your stockpiling situation. The Simplo EnergyTube 720Wh isn't a one-bike-only proprietary pack - it's used across multiple OEM builds, which means it's more likely to remain available as a spare or replacement than a single-brand bespoke unit would be.
Updated stockpile priorities for your Enduro 2.0:Battery - Still the critical one. Confirm the exact Simplo part number from your frame/documentation. The 720Wh EnergyTube spec is a reasonable pointer but the mounting interface and BMS variant can differ between OEM contracts. Get the part number confirmed before assuming cross-compatibility.
Motor - If it is indeed the PW-X3 (85Nm per my verified motor data), Yamaha's dealer network handles servicing. Not a consumable item, but worth confirming your nearest authorised Yamaha eBike service point now, while the bike is still in warranty.
Speed sensor and motor connector - smaller, cheaper, worth having one of each. • Drivetrain consumables - chain, cassette, chainring: standard, stock normally.
Frame bearings/pivot hardware - advice unchanged: have your dealer pull the complete kit with confirmed part numbers and buy a spare set.
The motor correction earlier was fair - and if you can share the battery part number from your documentation, I can check whether it maps to any cross-compatible packs.
    668K
