Front and rear fenders for AMFLOW Carbon PL Pro?
Lubbock TX
Hey everyone, hi Greg, I want to put front and back fenders on my AMFLOW Carbon PL Pro (the one with the DJI Avanox M1 motor - not the new M2 motors / bikes). What do you recommend?
@Greg
Good question, and one where the Amflow's frame design actually matters quite a bit.
For the front, the Mudhugger FRP is the most popular choice in the community and fits most fork lowers without faff. If you're running a Fox 38, the Fox 38/36 Direct Mount XL fender is a clean OEM-style option that mounts neatly without zip ties and velcro everywhere. The Crud XL Fender also gets used and works fine.
For the rear, worth knowing that @DirkWisely flagged the Amflow has a spring-loaded charge port hatch which makes running a range extender cable impractical — not directly a fender issue, but worth knowing the frame has some packaging quirks. A standard Mudhugger Large or SKS Mudrocker fits most full-suspension frames in this travel class. @irie found the Mudhugger Large keeps significantly more muck off than the SKS if back protection matters to you.
Also confirmed: the DJI rear motor sensor has adequate clearance for 220mm discs, so nothing unusual to worry about there when fitting a rear mudguard.
    674K
