Bullmonster
Part | Bolt/Screw Type | Torque (Nm) | Tool | Miscellaneous |
Speed Sensor | 1 x M6x12 | 5Nm | 5mm Allen Key | Loctite |
Frame Air Intakes | 2 x M3x10 | 0.1Nm max | 2mm Allen Key | |
Rectangle Cover | 2 X M2,5x4 | w/ Feeling | 2mm (special tool) | |
Mounting Blocks to UR Cert | 4 x M5x10 | 3Nm | 3mm Allen Key | |
Mounting Blocks to Battery Control Box | 4 x M3x12 | 0.3Nm | 2.5mm Allen Key | |
UR-Rail to Frame | 2 x M5 | 5Nm | 12mm Spanner | |
Battery Rail Guide | 2 x M5x12 | 1 - 1.5Nm | 4mm Allen Key | Loctite |
Intergration Plug to Frame | 2 x M4x8 | 2.5 - 3Nm | TX20 | Loctite |
Charging Port Holder | 4 x 3x10 | w/ Feeling | TX10 | |
Charging Port Cover | 2 x 3x16 | w/ Feeling | TX10 | |
Side Remote to Bars | 1 x M3x6 | 0.3 - 0.4Nm | TX10 | |
Stem Bolts 'The Stem' | 4 x M5x18 | 5 - 6Nm | 4mm Allen Key | |
Display to Display Holder | 7 x M2x8 | 0.1Nm | TX6 (special tool) | |
Display Holder to Bars | 2 x M3x12 | 0.3 - 0.4Nm | 2.5mm Allen Key | |
Motor Bolts to interface | 2 x M8x50 | 18Nm | TX40 | |
Chain Guide to Retaining Plate | 1 x M4x12 | 1.5Nm | 3mm Allen Key | |
CG Retaining Plate to frame | 2 x M5x10 | 3Nm | 3mm Allen Key | |
Chainring Locknut | 1 x *Locknut* | 30Nm | Special Tool | |
Speed Sensor Disc | 6 x M5x10 | 2 - 4Nm | TX25 | |
Pannier Rack to Frame | 2 x M5x25 | 6Nm | 4mm Allen Key | |
Pannier Rack to Pannier Rack Holder | 2 x M6x14 | 7Nm | 5mm Allen Key | Loctite |
Pannier Rack to Frame | 2 x M5x20 | 4 - 5Nm | 4mm Allen Key | Loctite |
Pannier Rack / Fixing Protector | 1 x M5x16 | 4 - 5Nm | 4mm Allen Key | Loctite |
Mudguard to Frame | 2 x M5x16 | 4 - 5Nm | 4mm Allen Key | Loctite |
Mudguard to Pannier Rack | 2 x M5 x 20 | 4 - 5Nm | TX25 | Loctite |
Hanger | 4 x M5x12 | 4Nm | TX25 | Loctite |
Reflector Holder to Rack | 2 x M4x20 | 3Nm | TX25 | |
Cable Guide Horst-Link | 1 x M4x20 | w/ Feeling | 3mm Allen Key | |
SkyBeamer 5000 | 4 x M3x12 | 0.75Nm UND 0.9Nm | TX10 | |
OBU / Skidplate | 2 x M3x10 | 0.3 - 0.4Nm | 2mm Allen Key | |
Dropout cover to frame | 7 x M4x8 | w/ Feeling | 2.5mm Allen Key | |
Skidplate to Frame | 4 x M5x15/20 | 2 - 2.5Nm | 4mm Allen Key | Loctite |
