Bullmonster
Error ID | Error Group | Possible Cause | Action 1 | Action 2 | Action 3 | Action 4 |
4 | THROTTLE | C1: Wiring problem C2: Throttle issue C3: Voltage measurement on motor electronic | A1: Check connection to throttle | A2: Replace throttle | A3: Replace Motor (crosscheck) If issue is resolved -> replace motor and send motor to service with error log | Replace cable harness |
7 | POST | C1: Motor electronic issue | A1: Replace motor Send motor to service with error log | |||
8 | TRIPZONE | C1: Cable issue on rear peripheries C2: Motor current issue | A1: Check wiring to rear light or Econnect for shorts; Check open connectors | A2: Disconnect rear light and eConnect and check if error is persistent | A3: Replace cable harness | A4: Replace motor |
9 | BATTERY | C1: Connector problem at battery-connector C2: Battery issue C3: Cable issue | A1: Reinsert battery after checking battery contacts (battery and cable harness) | A2: Replace battery | A3: Replace cable harness | |
21 | HPF | C1: Invalid Parameter-File | A1: Reinstall software via Servicetool | |||
24 | GENERAL | C1: CAN connection to display (appears after SW update) C2: Broken display | A1: If error appears after SW update - ignore issue (possibly delete error log) | A2: Check display connection | A3: Replace display cable | A4: Replace display |
29 | FRAM | C1: Motor electronic | A1: Replace motor Send motor to service with error log | |||
29 | ELECTRONIC | C1: Motor electronic | A1: Replace motor Send motor to service with error log | |||
32 | BATTERY | C1: Battery issue C2: Wiring problem or Short circuit in peripherie components C3: Display cable short circuit C4: Motor electronic | A1: Replace battery | A2: Disconnect peripherie componentes (front and rear light, eConnect); If issue still exists replace cable harness | A3: Replace display cable | A4: Replace motor |
37 | BATTERY | C1: Battery issue C2: Problem with voltage measurement on motor electronic | A1: Reinsert battery after checking battery contact at cable harness | A2: Replace battery | A3: Replace cable harness | A4: Replace motor |
61 | SENSOR | C1: Broken DMS C2: Voltage measurement on motor electronic | A1; Replace motor Send motor to service with error log | |||
64 | ELECTRONIC | C1: Voltage measurement on motor electronic | A1: Replace motor Send motor to service with error log | |||
65 | SENSOR | C1: Short strong impacts on the pedals (issue is just temporarily) C2: Broken DMS | A1: Ask customer if issue occurrd once - if so ignore error and possibly delete error log | A2: Replace motor Send motor to service with error log A3: Ask if error occurred when hitting a rock or similar | ||
69 | ELECTRONIC | C1: Extreme board current measurement on motor electronic | A1: Replace motor Send motor to service with error log | |||
71 | ELECTRONIC | C1: Shifted ADC low reference | A1: Replace motor Send motor to service with error log | |||
72 | SENSOR | C1: Broken electronic sensor DMS | A1: Replace motor Send motor to service with error log | |||
73 | SENSOR | C1: Forces on pedal during start-up C2: Broken DMS C3: Problem with voltage measurement on motor electronic | A1: Ask customer if error occurred with forces on the pedals during start-up; Required is a system start without power (as feed) on pedals | A2: Replace motor if error occurs without forces on pedals during start-up. Send with error log to service. | ||
74 | SENSOR | C1: Forces on pedal during start-up C2: Broken DMS C3: Problem with voltage measurement on motor electronic | A1: Ask customer if error occurred with forces on the pedals during start-up; Required is a system start without power (as feed) on pedals | A2: Replace motor if error occurs without forces on pedals during start-up. Send with error log to service. | ||
75 | RETURN | C1: Battery timeout | A1: Reinsert battery after checking battery contacts | A2: Check that battery lock is tight enough | A3: Replace battery | A4: Replace cable harness |
81 | ELECTRONIC | C1: Motor was very hot C2: Temperature sensor broken | A1: Replace motor Send motor to service with error log | |||
82 | ELECTRONIC | C1: Motor was very hot C2: Temperature sensor broken | A1: Replace motor Send motor to service with error log | |||
87 | BATTERY | C1: Issue with cable harness C2: Problem with voltage measurement on battery electronic C3: Problem with voltage measurement on motor electronic | A1: Reinsert battery after checking battery contacts on cable harness | A2: Reinsert motor | A3: Replace battery | A4: Replace motor |
88 | BATTERY | C1: Wrong or defect charger C2: Batterie electronic C2: Problem with voltage measurement in motor electronic | A1: Check or replace charger | A2: Replace battery | A3: Replace motor Send motor to service with error log | |
93 | BATTERY | C1: Short circuit in main voltage C2: Battery issue | A1: Reinsert battery after checking battery contacts on cable harness | A2: Replace battery | A3: Replace motor | |
94 | BATTERY | C1: Battery issue | A1: Replace battery and send to service | |||
109 | ELECTRONIC | C1: Calibration Error | A1: Replace motor Send motor to service with error log | |||
117 | BATTERY | C1: Wiring problem Battery issue | A1: Check battery-lock | A2: Replace cable harness | A3: Replace battery |
