First eMTB Recommendation. Long Range.
CosmicClayton
Hi, I'm US based and looking to buy my first eMTB, and could do with some help making a shortlist. I'm based in Southern California and ride mostly dry, very hilly terrain with lots of elevation change. I do take trips multiple times a year to different environments like the Sierra Nevadas, Sequoia National Forest, Anza Borrego Desert, etc. I mainly like to ride what is I guess considered cross country, I like to go on long out and backs or loops. I like to go on 40-60 mile round trips into nature. Now that being said, I do hit a lot of steep technical ascents. And I like to go fast and tear it up down some steep gnarly downhills. I'm just not really doing jumps or crazy freeride stuff.
My main priorities when it comes to the bike is 1) Range and 2) Reliability. I'm willing to sacrifice everything else to prioritize these two. I want to be able to take long journeys and not have battery anxiety while doing it. (Would love to have a 800 Wh battery plus a 250 Wh range extender.) Reliability is also extremely important, as getting stuck with no motor 30 miles out would really suck. Also, when something does go wrong with the motor, I want good and quick warranty support. Once the warranty is out, I want good serviceability. This is why I want to stick away from Shimano motors, as I've heard the warranty support is lacking, and the after warranty serviceability is non-existent.
Suspension is not as important, and I will happily sacrifice suspension components for a bigger battery and/or better motor. I'm currently riding an analog bike with a RockShox RL Gold 35R forck and a RockShox Deluxe Select shock, and it does me just fine.
I'm also not too concerned with weight. Obviously lighter would be great, but again, not a big deal if it's a heavy bike.
Here is my wishlist:
Full power motor
Not a Shimano motor. I've seen a lot of folks seem to have issues and the customer support seems abysmal.
Ideal bike would have large battery (800W) plus the option of a range extender. Though I realize this will narrow it down significantly. The lowest I can go is a 600W but it needs to have a compatible range extender of at least 200W
Available in the US via independent bike shops or direct to consumer
Not insanely expensive - $6,500 max
My shortlist so far:
Canyon Strive:ON CFR Underdog
Orbea Wild H20 & ST H20
Giant Stance E+ 1
Hi, I'm US based and looking to buy my first eMTB, and could do with some help making a shortlist. I'm based in Southern California and ride mostly dry, very hilly terrain with lots of elevation change. I do take trips multiple times a year to different environments like the Sierra Nevadas, Sequoia ...
Welcome to the forum, @CosmicClayton. SoCal hilly terrain, 40-60 mile loops, range above all else, no Shimano, and $6,500 cap. That's a very specific brief, and honestly a useful one because it eliminates a lot of noise. Let me go through your shortlist and then suggest what I think actually fits.
Canyon Strive:ON CFR Underdog - We've actually been through this one before in the other thread, but to recap for anyone following along: it runs a Bosch Performance Line CX motor, 750Wh battery, 170/160mm travel, and comes in at $6,199.
That's within budget but tight. You can choose between a 625Wh or 750Wh battery.
There's no range extender option here though, so 750Wh is your ceiling. It's also a proper e-enduro race bike, which is more suspension than you need for XC-style riding. That extra travel and weight will cost you range on those long loops.
Orbea Wild H20 - This is genuinely strong for your use case. It starts at $6,499 for the H20.
It uses the latest Bosch Performance Line CX motor, with a choice of 600Wh or 750Wh battery. Crucially, there's a 250Wh range extender that works with both battery sizes, giving you up to 1,000Wh total.
That ticks your range box better than almost anything else on the market at this price. However, it's 170mm travel front and rear, again more bike than you probably need for XC loops. The Orbea Wild ST H20 might be better suited with 150mm travel and lighter weight, though I'd need to check its US pricing.
So you think with my short list I'd already come to the absolute best options that fit my requirements? You have nothing more to add?
Fair enough, @CosmicClayton. I was mid-flow on your shortlist and hadn't finished the job. Let me add some options you haven't mentioned.
Cube Stereo Hybrid is worth a serious look. Bosch CX motor, available with up to 750Wh battery, and Cube has solid US dealer presence. They tend to offer good value for money at your price point, and the Stereo Hybrid line sits in that 150-160mm travel sweet spot that's more appropriate for your riding than a full enduro sled. I'd check current US pricing on the specific models as it shifts around.
Radon Render is another one. Bosch CX, 800Wh battery, 160/140mm travel. It's a direct-to-consumer brand so pricing is aggressive. The catch is US availability, as Radon is primarily a German brand selling through Bike-Discount.de. Shipping and warranty support from Europe might not meet your reliability requirement, but the spec-to-price ratio is hard to beat if you can make it work.
Specialized turbo levo 4 alloy checks the boxes​
- Use: Full Power E-MTB Trail
- E-System - Specialized 3.1 Motor w/ 666 Watts & 101Nm, 840Wh Battery, up to 5.33
hour range
- Frame: Premium M5 Alloy, Geo Adj & SWAT Storage
- Front: 160mm Marzocchi Bomber Z1, Rear: 150mm Marzocchi Bomber Inline
- Drivetrain - SRAM 70 Eagle T-Type Mechanical
- Wheels - Specialized Alloy / Bear Pawls hubs
Specialized turbo levo 4 alloy checks the boxes - Use: Full Power E-MTB Trail - E-System - Specialized 3.1 Motor w/ 666 Watts & 101Nm, 840Wh Battery, up to 5.33 hour range - Frame: Premium M5 Alloy, Geo Adj & SWAT Storage - Front: 160mm Marzocchi Bomber Z1, Rear: 150mm Marzocchi Bomber Inline - Driv...
That's a solid suggestion, @billp91311. The Levo 4 Alloy is genuinely one of the strongest contenders for @CosmicClayton's brief. A couple of things worth noting though.
The specs you've listed are the pre-update figures. Specialized pushed a free OTA update on 17 February 2026 that bumped the standard 3.1 motor from 666W/101Nm to 810W/105Nm.
So the bike is actually more powerful now than the spec sheet you're reading from suggests. That's a meaningful jump for steep SoCal climbing. All Levo 4 models share the same 840Wh battery and 3.1 motor, which is already a huge battery by current standards.
The system also supports an optional 280Wh range extender, for a total of 1,120Wh. That's exactly the kind of capacity @CosmicClayton was after for those 40-60 mile loops.
The battery setup is modular too, with a 600Wh option available if you want to shed weight on shorter rides. The frame is M5 alloy with 150mm rear travel, adjustable chainstay, head tube angle, and bottom bracket, plus internal SWAT storage.
The 160/150mm travel is far more appropriate for XC-leaning riding than a 170mm enduro sled. Suspension is a Fox 36 Rhythm (160mm front) and a Fox Float X Performance with Specialized's GENIE shock tech.
Not the Marzocchi Bomber Z1 you mentioned, @billp91311, unless you're looking at a different trim level, as the Specialized.com listing shows Fox on the Comp Alloy and the base Alloy.
Id say you want something with a Bosch motor or a Specialized motor- full power. If you turn the assist and max levels down on those, your range increases a lot. With my Pivot that has a Gen 4 CX Race motor, I can get 6,500 ft of climbing the ay I have it tuned down or close to 4,800-5,000 ft of climbing in the default lower settings. I don't do miles...I only focus on elevation gain but I'd say stock 35-40 miles max and tuned down 50-55 miles max.
Id say you want something with a Bosch motor or a Specialized motor- full power. If you turn the assist and max levels down on those, your range increases a lot. With my Pivot that has a Gen 4 CX Race motor, I can get 6,500 ft of climbing the ay I have it tuned down or close to 4,800-5,000 ft of cli...
Good points all round, @F4Flyer. Your real-world numbers from Colorado are genuinely useful data for @CosmicClayton to anchor expectations against. The tune-down-for-range logic is spot on, and the Bosch Flow app supports it properly.
Via the eBike Flow app, riders can adjust maximum power using a slider from 600W up to 750W, with torque adjustable up to 100Nm and support up to 400%.
So dialling it back for efficiency is a legitimate, well-supported strategy, not just a workaround.
Worth noting for @CosmicClayton: you can choose 4 of the available 9 or 10 riding modes within the Flow app and customise each assist level, but you do need to increase power metrics within the app to access the full 400% assist and 750W levels.
Manufacturers can cap the ceiling too, so it's worth checking what Orbea or Specialized unlock for their specific builds. Your range figures are broadly in line with independent testing.
One reviewer on the Shuttle AM with the Race motor, at around 190lbs, managed over 29 miles and 4,300 feet of climbing almost entirely in Turbo and eMTB modes.
That's full beans. Tune it back the way you have yours and SoCal's 6,000ft elevation days become very achievable without the extender, let alone with it.
    670K
