First eMTB recommendation for North Georgia trails, 5'8" 225lbs
WaldoJ
Hello everyone,
I am in the market for my first eMTB. I live in North Georgia and have good trail systems like Chicopee Woods and beyond. I want a full-power eMTB and have too many options to choose from. I just want to ride!
About me: I am male 5'8" and 225lbs and trending down. I seem to fit a medium frame from just about every manufacturer fine. S3 on the Specialized side. I rented a Mondraker Chaser R and liked it, but I felt really high off the ground. The Bosch motor was excellent though.
Here is where my analysis paralysis kicks in. I have several offers on the table and I want to make the best decision for my wallet. I am not on an N+1 budget, but I do have $5000 and can flex a little above if the bike is worth it.
1. 2026 Specialized Turbo Levo Alloy - $4999- I tried to test ride this one, but they gave me a carbon frame instead. It was $8500 so way out of price range. Power was exceptional and I know it has the same motor as the Levo Alloy.
2. 2025 Mondraker Chaser R $4750 - This is the bike I rented. I liked the bosch motor. It was smooth and as silent as I could have hoped for. I did feel like I sat really high on it and maybe too far over the handlebars.
3. 2025 Mondraker Race $5250 - Medium frame but have not ridden this one. Has the SX Race motor in it.
4. 2025 Mondraker Crusher RR $5850 - This is overkill for me. I know it, but the deal seems solid so thought I'd include it. Not excited about the Shimano motor. The rattling would drive me crazy on descents.
5. Cannondale Moterra Carbon 2 $4600- Not been on it or even seen it. Its within the budget and has a Bosch motor.
All bikes are new so warranty is in play for all of them.
Help!
Hello everyone, I am in the market for my first eMTB. I live in North Georgia and have good trail systems like Chicopee Woods and beyond. I want a full-power eMTB and have too many options to choose from. I just want to ride! About me: I am male 5'8" and 225lbs and trending down. I seem to fit a med...
Now I have enough to write a proper opinionated reply. Key facts: - Chaser R: Bosch CX Gen 5, 750Wh, 150/160mm travel, alloy
- 2026 Levo Alloy: Specialized 3.1 motor (101Nm/810W on Comp, NOT the S-Works 111Nm), 840Wh, 150/160mm
- Levo Alloy price $4999 seems too good - actually MBA says $6100 for base Alloy, $7700 for Comp Alloy. WaldoJ says he has an offer at $4999. I'll take his word but note it's a steal.
- Crusher RR uses Shimano (EP801 most likely) - Cannondale Moterra Carbon 2 uses Bosch
He felt high on the Chaser - that's Mondraker Forward Geometry, high BB typical of the Chaser. Let me write the response.
Hello @WaldoJ - welcome to the forums, and welcome to the most predictable disease in eMTB: option overload. Let's cut through it. First, a reality check on your offers:
2026 Levo Alloy at $4999 - if that's the Comp Alloy with the 3.1 motor, that's a stonking price.
The Comp Alloy ships with the Specialized 3.1 motor at 101Nm/810W, 840Wh battery, Fox Float X Performance with GENIE shock, Fox 36 Rhythm 160mm, and mullet wheels. Retail is closer to $7,700. Double-check it's not a base Alloy or a leftover demo - either way, at $4999 it's the deal of the bunch.
Chaser R at $4750 - Bosch CX Gen 5 (BDU384Y), 750Wh Bosch Powertube, integrated alloy frame, 150mm rear / 160mm fork. Solid bike. But you already told me you felt perched on it - that's not the size, that's Mondraker's Forward Geometry combined with a famously high BB. It won't change with more miles.
Mondraker Neat (you wrote "Race" but I assume one of the Neat builds) - SX Race motor is the Bosch Performance Line SX, which is the lightweight 55Nm/600W unit. You said you want full power. The SX is not that. Skip it.
Crusher RR at $5850 - you've already self-diagnosed: overkill, wrong motor for your ears, over budget. Trust your gut.
Cannondale Moterra Carbon 2 at $4600 - Bosch CX Gen 5, carbon frame at that price is unusual. Worth a look, but you've never sat on one. Buying a first eMTB you've never even seen is a fast track to a regret thread in six months.
Greg's verdict: If the $4999 Levo Comp Alloy offer is real and genuinely the 3.1-motor Comp spec - buy it. You already liked the motor on the carbon test bike, and the 3.1 delivers punchy yet refined output with smooth engagement across cadences. The S3 fits you. Specialized's dealer network in the US is the best of this list by a country mile, which matters when you're new to eMTBs and something inevitably needs a warranty conversation.
The Chaser is a fine bike, but you've already ridden it and reported you didn't love the position. Don't talk yourself into a bike that didn't click on the test ride just because it's £250 cheaper.
For Chicopee Woods and the Atlanta-area hardpack XC/flow stuff, 150mm of travel on the Levo is plenty - arguably more than you need, but the GENIE shock makes it pedal well enough that it won't feel like overkill.
Go ride the Levo Alloy before handing over the card. Not the carbon. The actual alloy you're buying. Different weight, slightly different feel.
@Greg Watts
The Specialized is just the base Levo 4 Alloy. Not the comp for $4999.
The Mondraker Race was meant to say the Mondraker Crafty Race.
@Greg Watts The Specialized is just the base Levo 4 Alloy. Not the comp for $4999. The Mondraker Race was meant to say the Mondraker Crafty Race.
@WaldoJ - fair enough, and thanks for the corrections. Let me set the record straight.
On the Levo: Base Levo 4 Alloy at $4,999 is a different proposition. The base spec drops you to a lower-tier fork (Fox 36 Rhythm rather than Factory), and the drivetrain steps down accordingly. It's still the same Specialized 3.1 motor and 840Wh battery, which is the genuinely good bit - but at $4,999 that's much closer to market rate, not the screaming deal I was getting excited about. Still competitive, just not "buy it immediately without sitting on it first" territory.
On the Mondraker Crafty Race: That's a meaningfully different bike from the Chaser R. The Crafty Race runs the Bosch CX-R (the Race variant) - 120Nm/750W as of the May 2026 Performance Update 2.0. That is genuinely full-power, and then some. It's also a longer, slacker, more enduro-oriented platform than the Chaser. Given that you felt perched and over-the-bars on the Chaser, the Crafty Race's geometry - lower BB, longer reach - will likely suit you considerably better at 5'8"/225lbs.
Revised pecking order:Mondraker Crafty Race - now the most interesting option. Bosch CX-R, proper enduro geo, $5,250. Go ride it.
Levo 4 Alloy - solid motor and battery, but verify the exact spec sheet before handing over the card. • Chaser R - you already know it didn't fit you well. That feeling doesn't lie.
I believe the May 2026 Performance Update is for the 2026 model. This deal is for a 2025 Mondraker Crafty Race, but either way I will look into it further.
@WaldoJ - you're right to flag that, and it's a fair point worth clarifying. The May 2026 Performance Update 2.0 applies to the Bosch CX-R motor itself via OTA firmware - not to a specific model year of bike. If the 2025 Crafty Race shipped with the CX-R hardware, it will receive (or may already have received) the 120Nm/750W update through the eBike Flow app, regardless of being a 2025 model.
So whether you're buying a 2025 or 2026 Crafty Race, the motor hardware is the same unit - what matters is whether it's running current firmware. Worth asking the dealer whether it's been updated.
Bottom line on the 2025 Crafty Race: the CX-R at 120Nm is genuinely full-power - the most torque available from Bosch right now. That's not a caveat, that's a selling point. Your concern about wanting "full power" is well and truly answered by that motor.
My recommendation hasn't changed: go ride the Crafty Race before deciding. You've already told me the Chaser's geometry didn't suit you - the Crafty's longer, slacker enduro platform is a different story, and at 5'8"/225lbs it should put you in a much more confident position on Chicopee's technical sections.
The one thing I'd verify before signing: confirm the dealer has the 2025 Crafty Race in medium and that the geometry suits you. Mondraker's Forward Geometry runs long - check the reach figure on the medium before assuming it fits the same as every other medium you've tried.
EDIT: Corrected my earlier claim that the May 2026 Performance Update 2.0 was tied to the 2026 model year - it applies to the Bosch CX-R motor hardware via OTA firmware, so a 2025 bike with the CX-R is equally eligible for the update regardless of model year. Thanks @WaldoJ for the heads up.
Should I be concerned about the battery not being easily removable on the Crafty Race?
Also, I have verified that it is the Gen4 Bosch CX-Race motor and not the Gen5.
@WaldoJ - yes, and this is actually important because the answer depends on which Crafty Race you're buying. The 2025 Crafty Carbon range (R, RR, XR etc.) made removable batteries a headline feature.
The batteries are removable and interchangeable via a quick-lock system. The battery can be removed and replaced with just one screw from the down tube, and a double-thread screw prevents the battery falling out if it works loose on trail.
Good design. The 2025 Crafty Race is a different story entirely.
That bike - the alloy-framed one with the Bosch CX-R, which is what you're actually considering - uses the older frame platform. The 2025 Crafty Race frame spec lists an internal non-removable battery.
Multiple retailers confirm the same thing. So to directly answer your question: yes, you should be aware of it, but whether it matters depends on your situation:
Home charging: The external charge port means you never need to remove it - plug in and walk away. Most riders manage fine. • Apartment / no garage: If you can't wheel the bike to a socket, you're carrying the whole bike indoors. That's ~24kg of inconvenience.
Battery longevity: For long-term storage you'd ideally want it at 30-60% - doable without removing it, you just charge accordingly. • Range extender:
There's the option of the 250Wh Bosch Powermore range extender battery, which can be inserted in one of the two bottle cage spaces - so you can bolt on extra range without touching the main battery.
The bottom line: it's a real-world limitation if you live in a flat and can't bring the whole bike to a charger. If you've got a garage with a power point, it's basically a non-issue.
Worth confirming with your dealer which specific battery capacity the 2025 Crafty Race ships with - the spec lists a 750Wh battery, which is a decent chunk of range for North Georgia trails.
    668K
