Right, the 2020 Trek Rail 9 (Gen 2 carbon) — let's get the numbers straight before we talk shocks.
Stock shock size: 230 x 57.5mm (metric, trunnion mount, standard 8mm hardware). That's been the Rail's rear shock dimension from 2020 right through to the Gen 4 (2024) before the Gen 5 refresh shifted to 205x65mm.
EXT Storia V3: EXT make the Storia V3 (and Lok V3) in 230x57.5mm trunnion specifically — it's one of their listed eMTB-friendly sizes. So yes, it physically fits.
The caveats — and they matter:
Spring rate. You're on a coil, so you need to get the rate right for the Rail's leverage curve. The Rail is moderately progressive but not hugely so — most riders find coil works well but you want EXT's recommendation based on rider weight (kitted) plus a tune code. Email EXT or their UK distributor (Mojo) with your weight and they'll spec the spring and tune. Don't guess.
Tune. EXT tune the damper to the bike. The Storia V3 for a Trek Rail will be a different tune to the same shock on a Specialized Kenevo. Ordering a generic one off the shelf is a recipe for disappointment.
Clearance. On the 2020 carbon Rail, coil shocks generally fit fine —
@irie runs a TTX22 coil (230x57.5) on a 2022 alloy Rail with a 525lb spring at 80kg ready-to-ride, which is a useful reference point. The Storia body is similar in profile.
Bottom-out. Coils are linear by nature. The Storia has a hydraulic bottom-out circuit which helps, but if you're a heavy rider or hit big hits, be aware the Rail's curve doesn't ramp up as much as, say, a Norco Sight VLT. Worth a conversation with EXT about HBO setup.
Verdict: Fits, will ride beautifully if you spec it correctly through EXT/Mojo with your weight and a tune code. Don't buy a used one off eBay hoping it'll be plug-and-play — coil tuning isn't generic.
For comparison,
@andyjayh runs a Storia on a Forbidden Druid and rates it highly when matched correctly to the bike.
What's your kitted riding weight and what are you running currently? That'll let me sanity-check whether the Storia is actually the right call versus, say, a Vivid Ultimate air which a few Rail owners here rave about.
