fenwick458
recently been having motor issues, I've documented it all over the past few weeks and am really just about to book it in with an Orbea dealer before the warranty expires on the 23rd Feb.
In a nutshell it's been spot on for all of 21 and 22, but on a ride on new years eve it started cutting out when descending, I put it down to a loose connection . but then next ride it started displaying error 510 and it's been increasingly hard to clear this. and as of today just realised the cutting out issue was likely "error 500" as today it did it a few times as I was watching the display.
heres all the details I've compiled, thought it would be worth sharing this to see if anyone has had anything similar?
31st Dec, whilst descending on the red north middle section at trail centre it cut out twice, by the time I noticed the screen was blank didn’t catch an error code. Once turned back on it worked fine both times
Jan 4th, attempted to replace frame bearings, replaced chainring with 34T direct mount (didn’t ride it after this)
Jan 9th had new frame bearings fitted at LBS
Jan 14th, 20km ride, first ride after having frame bearings replaced. When I set off it kept saying error 510 on the purion display, but resetting it cured it and it would work after that. Every time I stopped on the ride to go through a gate or clear an obstacle (3-4 times) it wouldn’t start again as it was saying error 510. Resetting it seemed to work and as long as I didn’t stop riding it was ok
Jan 21st, took motor cover off and inspected plugs, all looked fine. Rear magnet on the disc was covered in magnetic dust I removed all that and went for 30Km ride and it was fine, never displayed an error code once
Jan 28th , 5km ride along cycle track all fine
Jan 29th, displaying error 510 from the start, took approx. 20 resets to get it to go. Kept cutting out saying error 510, would take 5-10 resets to go again. Did 8.6km and it never did more than 1km without stopping
1pm after cleaning bike, Removed 34T direct mount chainring and replaced with the standard 32T one to see if it made a difference, short test ride around the block and it still says error 510 every few minutes, but resetting seems to work
3pm, rode into town and back, 1km each way, no problem
4th Feb, went to trail centre. Rode up to top of red north , on way down it cut out at roughly same place as 31st Dec. had to try and restart it 4-5 times before it would go, this time it said Error 500. It would stop working, show the code and then the display goes blank 2-3 seconds later unlike the error 510 which just stays there on the display
Rode back to visitors centre then did the blue, error 510 on the middle climb. Must have attempted to reset it 50 times trying everything I could think of (no pressure on the pedals, whilst freewheeling, with the bike stationary) and ended up pedalling all the way to the top with no assist, at the top I changed the mode from EMTB to tour, reset it and it worked! never threw a fault code again and I finished off the blue, and did the red north and the blue again with no problems. I did the remainder of the day in tour mode but tried out EMBT and turbo for little bits and that didn’t make a difference
anybody have any similar experience?
