EP8 turning off mid-ride
Gus
8
emtSpike61
A few of our group have the latest 2021 Merida E160 with Shimano EP8 motor.
Great bikes.
But yesterday one friend’s bike had 4 bars of battery and turned off an hour into the ride.
Pressing the on/off button, it would then light up, but turn off again in a couple of seconds.
We thought maybe removing and replacing the battery would help.
So he tried to remove the battery with the allen key, and the mechanism was broken and he was unable to remove the battery!
Back in shop now waiting for a fix.
Does anyone have any ideas or experience on this?
Jschlueter
22
13
Bentonville, AR
Great bikes.
I've seen similar issues on e8000 setups. It was a bad wiring harness. E020 code will appear sometimes.
flash
1,050
986
Wamberal, NSW Australia
Great bikes.
Twice on my 2021 e-160. Cause was an incorrectly installed knock block had allowed the cable that goes into the headset to get caught and crushed. I'm definitely not a fan of running the motor cable through the head set. I'm handy with a soldering iron so it was a quick fix. Happened again when I worked out the stopper for the knock block was too low on the steerer. Fixed that and now it seems all OK.
I really wish that Shimano would get on the wireless bandwagon. There's no reason the switch and display need to be wired at all. It'd be more reliable and neater too.
Gordon
cheetahdog2261
Dayton NV
Great bikes.
My ep8 motor would turn it self off , I found a loose wire from the motor to the display at the motor being loose. I plug it back in with a little silcone sealant around it to hold it in ln place. After about 4 hours ( to let the silcone set ) I went for a 11 mile ride with no problems. Hope this helps.
522K
