Has anyone changed front wheel bearings on an e160rs. How do you get the caps pff the hub? Thanks
Giff Active member Subscriber Oct 14, 2019 424 116 Cheshire UK Apr 28, 2022 #1 Has anyone changed front wheel bearings on an e160rs. How do you get the caps pff the hub? Thanks
H highpeakrider E*POWAH Master Aug 10, 2018 685 556 Peak District Apr 28, 2022 #2 The two big wheel locators just pull off. No idea about the bearings though as I swapped my wheelset out with some Hope Fortus 30's
Giff Active member Subscriber Oct 14, 2019 424 116 Cheshire UK Apr 28, 2022 Thread starter #3 Thanks Mine seem really tight. I’ll try with some sort of soft clamp. Good tip on the Hope replacements.
T Tribey Active member Jan 1, 2019 307 225 South Devon, UK May 18, 2022 #4 I used a bearing puller to first remove the locators, then remove the bearings.
