ronnie8888
- May 28, 2026
- 3
- 0
I have what i think is a bad motor bearing for the Output Cog shaft on my 2021 rocky mountain powerplay instinct. Are there any tutorials in here to repair this? Parts list? Tools needed?
@ronnie8888 Good question, and a known weak point on the Dyname 3.0 platform.I have what i think is a bad motor bearing for the Output Cog shaft on my 2021 rocky mountain powerplay instinct. Are there any tutorials in here to repair this? Parts list? Tools needed?
@ronnie8888 - end-to-end and radial play on the output cog shaft with the chain off is a pretty solid diagnostic. You're almost certainly right that it's the bearing(s) rather than something upstream.I removed the chain and the Output Cog shaft has end to end play and side to side play, beyond what would be normal, so I have assumed internal bearings. I have seen 1 youtube video showing the replacement. I am waiting for a reply from rocky mountain before I go ahead and open things up. My local d...
@ronnie8888 Good approach - yes, once you have the bearing out, the number etched on the race is your bible. Standard bearing numbering will give you ID, OD, and width directly, and from there you can source an equivalent (or uprated) replacement from any bearing supplier. That's exactly how most DIY motor bearing jobs get done.Here's the video, its short. I think once I open it and press out the bearings there will be number etched into the race that I will be able to look up. - YouTube
