Darfon BMS Problem on Maserati MC Trail S?
Hey everyone, battery darfon BMS problem I've got a Maserati MC trail s.
Welcome, @Gianca68. A Maserati MC Trail S with a Darfon BMS issue - right, let's dig into this.
The Darfon battery is found across a range of bikes (Merida, Maserati's bicycle arm, and others), and BMS faults on these units do crop up. From what we've seen on the forums, a classic Darfon BMS fault presents as the battery outputting enough current to power the bike and even spin the motor briefly on walk assist, but then the bike shuts down after 15 - 20 seconds without throwing any readable error codes on the display.
Does that match what you're seeing?
The BMS (Battery Management System) is the brains of the battery pack - it monitors cell voltages, temperature, and current. When it's unhappy, it shuts the whole thing down to protect the cells. The frustrating part is it doesn't always tell you why it's unhappy.
A few things worth checking before assuming the BMS itself is dead: it's actually more likely the battery has an out-of-balance cell or a bad cell than a fried BMS - many BMS units will simply refuse to run if one cell group is significantly lower than the rest.
To help diagnose properly, it'd be really useful to know: • What symptoms are you getting exactly? (won't charge, won't power the bike, shuts off mid-ride, error codes?)
• How old is the battery and how many charge cycles roughly?
• Any recent crashes, water ingress, or the bike been stored for a long period?
If the bike is under warranty, that's your first call - Maserati e-bikes are distributed through specific dealer networks and Darfon battery replacements under warranty are a known process. If it's out of warranty, a dealer with Shimano/Darfon diagnostic tools can read the BMS data properly and confirm whether it's a cell issue or the BMS board itself.
Give us more detail on the symptoms and we'll narrow it down.
the bike and the battery is new but was stored since 2021 … battery and bike where newer used or changed..
the battery unboxed was completely mute and unrecognised by his charger 🙄 … a wrote to Darfon and I’m waiting an answer.
The bike
the bike and the battery is new but was stored since 2021 … battery and bike where newer used or changed.. the battery unboxed was completely mute and unrecognised by his charger 🙄 … a wrote to Darfon and I’m waiting an answer. The bike
This is a classic deep-storage BMS problem, and honestly one of the more frustrating situations to land in with a brand new bike.
Lithium batteries that sit uncharged for extended periods (five years in your case, since 2021) will self-discharge below the minimum cell voltage threshold. When that happens, the BMS goes into a deep-sleep or full protection lockout state - it refuses to accept a charge because it can't verify the cells are safe to charge. The charger sees nothing, the battery appears completely dead, and the LED indicators give you nothing. Exactly what you're describing.
The good news is this doesn't necessarily mean the battery is destroyed. The cells may still be recoverable if the voltage hasn't dropped too far. The bad news is it's not something you can fix yourself without specialist equipment.
@Gianca68 - worth knowing that Darfon BMS units in protection mode can show 0V output despite the pack still having voltage internally, which is exactly the protection lockout behaviour. A technician with a bench power supply can sometimes "wake" the BMS by applying a carefully controlled charge directly to the cells, bypassing the BMS just long enough to bring them above the lockout threshold. This is not a DIY job.
Since the bike and battery are genuinely new and unused, you have a strong warranty argument regardless of storage age. The product was never put into service and the fault was present on first unboxing. Keep that framing when you follow up with Darfon. If they drag their feet, escalate to the dealer or distributor you purchased through - a new product that's never worked is a consumer rights issue, not just a warranty claim.
Good call writing to Darfon directly. Let us know what they come back with.
I’ll write u as soon as I get an answer … thank u for helping me …. U confirmed me what I was thinking … I already gave the cell to specialist but I tel them to wait working on the batteries till mail answer is coming back 👍🏻👍🏻
Good plan holding off until Darfon reply. You've got a specialist already lined up and a solid warranty argument in your corner, so you're in a reasonable position despite the frustration of it all.
One thing worth flagging to your technician while you wait: even if Darfon come back and authorise a replacement or repair, having a baseline cell voltage reading from the specialist now would be useful evidence. If the cells have dropped catastrophically low over five years of storage, that data strengthens your case that the battery left the factory in an unserviceable condition, or was stored incorrectly somewhere in the supply chain before it reached you. Either way, it points away from user error.
Good luck with the response. Darfon are generally reasonable to deal with from what we've seen, so hopefully they come back with something constructive. Keep us posted, @Gianca68.
    668K
