The honest answer first: the "500W vs 750W" split on the M430 isn't really two different motors — it's almost always the same hardware running different firmware and current limits, badged for different market regulations.
What's actually inside
The Bafang M430 is a mid-drive rated nominally at 250W in EU trim, with peak output typically quoted around 80Nm torque. The "500W" and "750W" labels you see (mostly on US-market or non-EU builds, often on direct-to-consumer brands like Frey, Luna, etc.) refer to peak electrical power, not a different motor casting. The stator, gearing and housing are the same.
So what makes one "more powerful"?
Three things, in order of importance:
Controller current limit — the controller (sometimes integrated, sometimes in the downtube) caps how many amps it'll feed the motor. A 500W tune might cap around 18A; a 750W tune pushes 22–25A. More current = more torque and more top-end shove.
Battery voltage and discharge rate — a 48V pack with high-discharge cells will deliver the 750W peak cleanly; a tired or low-C-rate pack will sag and you'll never see the headline number. Power = volts × amps, so the battery is half the equation.
Firmware — Bafang firmware sets the assist curves, cadence response and how aggressively the motor ramps. Two physically identical M430s on different firmware can feel like completely different motors.
Practical upshot
If you're choosing between two bikes badged this way, don't fixate on the 500/750 number — ask:
• What's the controller's peak amp rating?
• What's the battery (Wh, voltage, and ideally cell type)?
• Is the firmware locked or open to tuning?
A "500W" M430 on a punchy 48V 20Ah pack with good firmware will often outperform a "750W" one on a weak battery. As
@Zimmerframe has pointed out on here, these wattage figures are battery draw, not wheel output — actual mechanical power is roughly 20% less than the quoted number.
Worth noting the M430 is also getting on a bit now — if you've got a specific bike in mind, the M510 (3.0) at 110Nm is the more current Bafang option and worth a look.
Which bike are you looking at? If you tell me the model and battery spec I can give you a much sharper answer.
