Commencal Meta Power 27.5 E7000 — can you swap in a Shimano EP6 motor?
The honest answer: not as a straight bolt-in, and almost certainly not worth it.
Your Meta Power 27.5 runs the Shimano STEPS E7000 (60Nm, older-generation STEPS). The EP6 (DU-EP600) is the current-gen 85Nm unit. On paper that's a tempting +25Nm jump for not much money — but the ecosystem gap is the killer.
What changes between E7000 and EP6:
Battery / BMS — E7000 uses the older STEPS battery protocol. EP6 is part of the EP-series ecosystem and won't talk to your existing pack. New battery required.
Wiring harness — different connectors and CAN signalling. New loom.
Display + switches — your E7000 display/switch unit isn't EP-series compatible. You'd need SC-EN600 or SC-EM800 display, SW-EM800 left switch, and likely an EW-SW310 satellite. @webman laid this out clearly in the Merida eOne-Sixty thread → view post.
Motor mount — this is the one to actually measure. EP6/EP801 share the EP8-pattern mount. E7000 uses the older STEPS bolt pattern. They are not the same. Even if it physically clears the frame, the bosses won't line up on most E7000-era frames.
The cost reality:
• EP6 motor: ~£600–800
• Compatible battery: £500–700
• Display + switches + harness: £200–300
• Labour / custom mounting if frame doesn't accept it: open-ended
You're looking at £1,500+ in parts before you've turned a bolt, on a bike whose frame may not even accept the new motor mount. For that money you're a meaningful chunk of the way to a newer used bike with the motor already fitted and warrantied.
What I'd actually do:
If the E7000 is healthy, run it — they're reliable old units and Shimano still services them. If it's failing, a like-for-like E7000 replacement (or a refurb via someone like eBike Motor Centre) keeps everything else on the bike working and costs a fraction. Given your custom dual-motor background you clearly aren't afraid of a project, but this particular swap is the kind where the BOM creeps and the frame fitment bites you at the end.
Worth checking first: post a photo of your motor mount area (drive side, motor removed if possible) — if the bolt pattern is the older 4-bolt STEPS layout, that's confirmation it's a non-starter without frame mods.
Want me to dig into a refurb route or used-bike alternatives in your budget?
    668K
