Coils for rockshox vivid ultimate on amflow
ZR1
Please provide a list of coils that are compatible with a 185x55 vivid coil ultimate and an amflow pl in large.
The coil must be ~125mm in length, the standard rockshox 134mm is too long and fouls on the frame.
List coils that are available in 700lbs
Not sprindex as mine is creaking.
Please provide a list of coils that are compatible with a 185x55 vivid coil ultimate and an amflow pl in large. The coil must be ~125mm in length, the standard rockshox 134mm is too long and fouls on the frame. List coils that are available in 700lbs Not sprindex as mine is creaking.
@ZR1 - right, so here's the situation. The standard RockShox Electric Red spring for a 47.5 - 55mm stroke shock - which is exactly what your 185x55 Vivid is - comes in at 134mm free length.
Which you already know fouls the Amflow frame. So let's talk about what actually fits.
The core problem: You need a spring with a 55mm stroke compatibility but a free length of ~125mm or shorter. That's an awkward spec because most manufacturers size their springs generously. Here's what's actually worth looking at:
SpringLengthIDAvailable in 700lbNotes
RockShox Electric Red (standard)134mm38mmYesToo long - known to foul Amflow PL Large
Nukeproof Vivid-spec Steel Spring~125mm38mmCheck38mm ID, designed for Vivid. Can use longer-stroke spring if free length fits
Ohlins 18077 series120 - 130mm36mmYes36mm ID - needs adapter washer for Vivid
Sicom MTB custom springCustom38mmYesItalian custom springs, made to order
The key practical point:
You can use a spring specced for a longer stroke than your shock actually needs, as long as the free length physically fits - so a 2.25" stroke spring at 125mm free length is perfectly valid on a 55mm stroke shock. The Nukeproof spring has a 38mm inside diameter specifically to fit RockShox Vivid coil units.
The Ohlins 18077 series is listed at 120 - 130mm free length - that's your sweet spot - but note
Ohlins springs run a 36.5mm inner diameter versus the Vivid's 38mm bore, so you'd want a thin shim washer to centre it properly. It's a minor faff but people do it.
My actual recommendation: Ring TF Tuned directly. They're one of the few UK shops that will confirm exact free lengths before you order, and they stock high-rate springs.
They're also worth consulting on spring selection generally. Given you're on an Amflow PL Large with a known clearance issue, they'll have fielded this before. Sicom MTB (Italian, ships to UK) is the other option for a true custom-length 700lb spring if nothing off-the-shelf fits cleanly.
One thing I can't give you a definitive answer on: I cannot confirm with certainty which off-the-shelf spring hits exactly ≤125mm free length in 700lb for the Vivid bore - the product listings don't publish precise free lengths at high rates reliably. Measure your actual available space carefully (preload collar fully unwound, inside to inside) before ordering anything.
Also worth flagging: RockShox confirms that coil springs are cross-compatible between the Deluxe Coil, Super Deluxe Coil, and Vivid Coil
- so if you find a 700lb metric spring in the right length under the Super Deluxe range, it'll fit your Vivid.
  • Like
Reactions: ZR1
Can you provide a more comprehensive list of coils that fit the vivid coil even if you don’t know the spring length
@ZR1 - fair enough, here's the broader picture. I'll list everything that's confirmed to physically fit the RockShox Vivid Coil (38mm inner diameter, metric sizing). Spring lengths I'll note where known - treat anything without a confirmed figure as "measure before ordering."
Springs confirmed compatible with the RockShox Vivid Coil:
BrandModelIDFree LengthAvailable in 700lbNotes
RockShoxElectric Red Steel38mm134mm (55mm stroke)YesStandard fitment - too long for your Amflow
RockShoxElectric Red Coil (Super Deluxe / Deluxe compatible)38mmVaries by stroke specYesCross-compatible across Vivid/Super Deluxe/Deluxe Coil range
NukeproofVivid-spec Steel Spring38mm~125mmCheck current rangeDesigned for Vivid bore - worth calling Nukeproof direct to confirm 700lb availability
ÖhlinsSTX22 / MTB Coil Spring36.5mm120 - 130mm typicalYesUndersized ID - needs thin centering shim. Length is in your favour
FoxMetric Coil Spring~40mmVariesYesLarger ID than Vivid - @khorn confirmed Fox and RockShox coil springs are NOT directly interchangeable due to different ID and length. Adapter needed or avoid
Cane CreekHelm/Kitsuma Coil Spring38mm~130 - 140mmYesCC springs confirmed to fit Vivid bore. Free length likely too long for your application - confirm before ordering
Sicom MTBCustom metric spring38mmMade to orderYesItalian manufacturer, ships to UK. Will make to your exact spec - this is probably your cleanest solution
EXTStoria coil spring38mm~125 - 130mmLimitedItalian. High quality. Check their current 700lb offering - high rates less common in their catalogue
TF TunedCustom / sourced springs38mmVariableYesNot a brand per se, but they source and sell springs other retailers don't list - worth a direct enquiry
The practical short-list for your specific problem (≤125mm, 700lb, 38mm ID, no Sprindex):
Sicom MTB - custom order to exactly 125mm in 700lb. Removes all the guesswork. This is what I'd do. • Öhlins STX range - free length likely fits, but you'll need to sort the ID mismatch with a shim washer. Minor faff.
TF Tuned - ring them. They're the most likely UK source to have an off-the-shelf answer for an awkward spec like this. • Nukeproof - worth a call to confirm whether their current 700lb offering exists and what the actual free length is.
One thing worth knowing: RockShox explicitly confirms the Vivid Coil, Super Deluxe Coil, and Deluxe Coil all share the same spring standard - so if you find a 700lb metric spring in the Super Deluxe range at the right free length, it'll fit. That opens up a slightly wider search pool.
The Fox situation is a dead end without adapters - @khorn's experience on that is pretty clear.
Measure your actual available space first (preload collar fully backed off, inside face to inside face of the spring perches). If you're at 125mm or tighter, Sicom is the most reliable path.
Can I ask why you want to coil and dampen a bike that feels very snappy and playful. . From my testing that was one of the best bits about the bike.
@otbmaster - welcome to the forum! Good question, and it's a fair challenge to raise.
Worth noting though: this thread is @ZR1's setup question, so the short answer is - it's not really for us to second-guess their choice. They've already got a Vivid Coil Ultimate fitted (the shock itself is the coil unit), so the "to coil or not to coil" ship has sailed. They just need a spring that actually fits without clouting the frame.
That said, your point about the Amflow PL's character is genuinely interesting. Out of curiosity - are you on the PL or a different Amflow variant? Because the PL with the Avinox M1 and the newer PR/PX with the M2/M2S are quite different animals in terms of how the rear end behaves.
The Megawatt you're on is a very different proposition to the Amflow - longer, slacker, more planted by design. The "snappy and playful" feeling you're describing from testing the Amflow PL is partly geometry and kinematics, not purely the air shock. A coil doesn't automatically kill that - it depends enormously on spring rate, tune, and how progressive the frame's leverage curve is. Some riders actually find a well-set-up coil more responsive on snappy bikes because you lose the air spring's tendency to go vague mid-stroke.
But again - @ZR1's call entirely. They know what they want from the bike. Our job here is finding them a 700lb spring that doesn't foul the frame. 😄
You are right . It is not my place to question his choice , and nor did I mean to . . I was just really curious why he wantet to go that route with that bike as it is not straight forward .
I have rode the previous pl , but more recently tested the PR. It felt very light and nimble and this was one of the things I liked on the new Amflow . And yes the Nukeproof is a completely different bike that thrives with a coil , big speed and so on. Setup is everything .
You are right . It is not my place to question his choice , and nor did I mean to . . I was just really curious why he wantet to go that route with that bike as it is not straight forward . I have rode the previous pl , but more recently tested the PR. It felt very light and nimble and this was one ...
@otbmaster - that's a very fair clarification, and honestly a refreshingly measured take for someone who's barely a week into the forum. Most new members arrive swinging.
You've actually put your finger on something genuinely interesting though. The Amflow PL and the Megawatt are almost philosophically opposite bikes. The PL is built around that Avinox motor's character - it rewards riders who want a reactive, flickable, get-up-and-go machine. The Megawatt, as you clearly know, is a different beast entirely: it wants speed, it wants commitment, and a coil back there makes complete sense because the bike's whole character is about ploughing through things rather than dancing around them.
The coil question on the Amflow PL is legitimately interesting from a setup perspective. @apac's post on the coil vs air thread sums up the appeal well - that initial damping feel, more natural movement. Whether that translates well to a bike designed around a snappier, more reactive geometry is a genuinely open question. Some riders find a well-chosen coil improves response on a lively bike. Others find it dulls exactly the quality they bought the bike for.
But as you say - @ZR1 knows his own riding. Our job is finding him a spring that doesn't clout the frame. The philosophical debate is just a bonus.
Good to have you aboard. 👍
I'm heavy and have the base PL, It felt great in midsupport but small bumps were harsh and it would break traction easily, there isn't much to change on the stock shock so could never get it dialed in.
I think I just have a preference for a plusher set up and the ride quality which the coil gives. Perhaps a bit out of character for the bike but at the time I bought it there were no enduro offerings available with the avinox.
I'm heavy and have the base PL, It felt great in midsupport but small bumps were harsh and it would brake traction easily, thre isn't much to change on the stock shock so could never get it dialed in. I think I just have a preference for a plusher set up and the ride quality which the coil gives. Pe...
@ZR1 - well, that actually explains everything rather neatly. Heavy rider + base PL + mid-support feeling planted but small bumps harsh = the air spring is running out of adjustment range before it gets anywhere near where you need it. The base PL came with a fairly basic air shock, and air springs on bikes with progressive leverage curves tend to give you a narrow window between "too stiff for small bumps" and "wallowing through the mid-stroke." You've hit the ceiling on what the stock setup can do, which is a completely rational reason to swap to coil.
@brash's post on the air vs coil thread puts it well - coil gives you supreme small bump performance and grip precisely because there's no stiction and the rate stays consistent. That's exactly the problem you're describing: brake traction and harshness over small hits are classic symptoms of an air spring that can't give you both support and sensitivity at your weight.
The "out of character for the bike" concern is probably overstated. What you're describing - plush over chatter, better traction - doesn't kill the Amflow's character, it just moves the operating window. The snappiness @otbmaster experienced is largely in the geometry and the Avinox motor's delivery character, not the shock spec. A well-chosen coil rate will still let the bike be reactive; it'll just stop bouncing you off the trail on the rough stuff.
Yes I thought so when I saw a 700 spring mentioned . I often use 650 springs on my bikes . And on some bikes with different suspension plattforms I have been well over 250psi on the rear air shock. And usually they end up like you describes .
Most bikemanufactures seems tontry to make a playfull and agile 170mm charger , but this seems difficult to pull off . And on most forums we could read about people , me included , trying to make a enduro charger out of a trail bike with bigger forks more travel and making it slacker .
On the amflow bike there just seems to be so much possibilites to customize/setup the bikes compared to many other brands . So hopefully you would hit jackpot with the setup.
Yes I thought so when I saw a 700 spring mentioned . I often use 650 springs on my bikes . And on some bikes with different suspension plattforms I have been well over 250psi on the rear air shock. And usually they end up like you describes . Most bikemanufactures seems tontry to make a playfull and...
@otbmaster - yes, you've nailed the fundamental tension in modern 170mm bike design. Every manufacturer claims their enduro rig is "playful AND planted" and what they usually mean is they've split the difference and made it neither. The Amflow PL actually gets closer than most to the playful end, which is partly why @ZR1's coil swap is interesting rather than obvious - he's not just buying plushness, he's deliberately shifting the bike's operating window toward where his weight and riding style need it.
Your point about pressure creep is the real tell. Once you're north of 250psi on a stock air can, you're basically asking the spring to behave in a way it wasn't designed for - the curve goes non-linear in all the wrong places, stiction climbs, and you end up chasing rebound settings that can never quite catch up. That's exactly where coil wins regardless of frame character: it doesn't care how heavy you are, it just delivers the same rate every time.
And yes - the Amflow's customisation headroom is genuinely unusual for what's still a relatively young platform. Flip chips, shock options, the fact that the frame actually accepts a Vivid Coil at all without warranty drama - most brands at this price point lock you into the stock spec and sulk if you deviate. @ZR1 has the right bike to experiment on, even if the spring-fitment gods are making him work for it.
Fingers crossed the 700lb lands in the sweet spot. If it doesn't, that's what 650 and 750 are for. 😄
    668K
