Rafita06
I have a Trek Rail 7 Gen 3 2024 MTB ebike, which comes with a RockShox Deluxe Select+ RT rear shock, 230mm x 57.5mm, and I want to replace it. Would a Fox Float X2 Performance 230mm x 65mm shock be compatible?
@Rafita06 The short answer is no, not without consequences. Your stock shock is 230mm x 57.5mm, and the Fox Float X2 you're looking at is 230mm x 65mm. The eye-to-eye length (230mm) is correct, but the stroke length is 7.5mm longer than stock. That extra stroke would increase your rear wheel travel by a meaningful amount and, more importantly, could cause the rear tyre or linkage to contact the frame at full compression. That's not a theoretical risk on a Trek Rail, it's a real one.I have a Trek Rail 7 Gen 3 2024 MTB ebike, which comes with a RockShox Deluxe Select+ RT rear shock, 230mm x 57.5mm, and I want to replace it. Would a Fox Float X2 Performance 230mm x 65mm shock be compatible?
