Chain lube suggestion please
Marke
114
71
West Yorkshire
After 18 months and 2500 km's I'm still loving my trek powerfly..... although it does seem to be drinking muc off chain lube like its going out of fashion.
5 to 10 euros for 120ml does seem a little excessive. Anyone got any better value suggestions? Can I use my motocross bike chain lube?
Madmatt75
43
58
London
Keep your muc off bottle and fill it with gear oil. It’s much cheaper than “specific “ lubes. I use it on my triumph speed triple and bicycle chains with no problems. Just don’t use too much.
Marke
114
71
West Yorkshire
Car/ motorbike gearbox oil would be perfect as it's cheap as chips. Not sure if it's sticky enough though - i thought it might get thrown off as the chain goes round. Maybe motorbike chain lube in a muc off container? I thought their might be a oil expect on here. To be honest i don't have a clue.
outerlimits
E*POWAH BOSS
1,241
1,574
Throw some candles in a saucepan and heat to liquid over a low heat. Add a bit of paraffin oil to the mix. Add chain and cook it. Cool, wipe off excess wax, refit and go ride.
Darren Bacon
46
17
nottinghamshire
I use gear oil. Apply with old tooth brush
Jamsxr
518
632
Recently switched from Muck Off to Pedro’s, it’s not any cheaper but it’s a far better product in my option. It attracts far less dirt/crap, meaning the chain + cassette don’t need cleaning as often and last longer.
Bndit
154
199
Finland
I`m a lazy guy so don`t want to lube my chains so often. i have found that Peaty`s all weather lube is best for that. It stays on for ”long” time and doesn`t attract dirt. I wash my chains with same muc off that my bike, dry them with muc off 94 after the wash and then lube them.
6,138
4,670
cleaning the chain is far more important than what lube to use. Regardless whether you use Mucoff or 3in1 it is not lack of lubrication that causes wear on the pins and rollers............it is dust/sand/mud etc. Far too much advice on this topic derives from road bikes that are not used in dirt, and for them a longer lasting lube with far less need to clean makes sense. For MTB if you want a chain to last it needs to be kept clean.............and just wiping it achieves nothing!!
Vaau839
8
12
Uk
Just don't use Mucoff and you're already ahead of the game by a lot. Wax, drip wax in all conditions is the reason why components last at least 5x longer compared to Mucoff
paquo
463
282
usa
this is why i use either clean ride or squirt wax often.No need to clean before application, takes 2 or 3 minutes and bike shifts perfectly again
Sander23
700
433
Belgium
It actually the bad lubes that attracts twice as much dirt what causes the faster wear rates. In that case a lube that attract less dirt and contamination is more important then a super clean chain
oceanskipper
38
North East
Putoline chain wax - applied hot (90 degrees)via a small deep fat fryer. Whole drivetrain lasts many times longer (I currently have a chain with 2500 miles on it showing less then .5 chain wear) . It stays fairly clean and lasts for ages between waxings.
Hobo Mikey
955
2,498
Where ever
GT 85 My bike gets washed down after every ride and then apply GT 85 on chain. (y) I was thinking of trying something else like Peatys. Link lube.
jimbob
518
429
East UK
How far do you go between waxes? I'm currently doing it every 100 miles which I think is too frequently.
Tony4wd
215
180
Oils attract dirt and the chain and sprockets turn into a gunky mess. I switched to Rock n Roll wax products and the drive train stays clean and my chain seems to be lasting well.
oceanskipper
38
North East
I probably do it every 150 or so in the winter and maybe 300 in the summer. Depends on what sort of conditions I’ve been out in. Tbh I could probably leave it longer as it never gets to the point where the chain is noisy. I think last summer I did it once and I do 50 miles a week.
I run two chains and alternate them so I’ve always got one ready to switch over.
Ark
395
332
Newcastle Upon Tyne
Pretty sure it's not thick enough to really help, especially on an ebike.
that telfon layer is leaves behind must be like 0.01microns thick
works great for polishing a frame though, especially if you have a gloss finish, it will make the frame look brand new, works good on plastics too
522K
