Cascade Components Transmission Derailleur Cage - SRAM T-TYPE
Singletrackmind
San Diego, CA
Any information if the Cascade Components Transmission Derailleur Cage will work on a SRAM XO AXS T-TYPE rear derailleur?
@Singletrackmind I don't have specific community data on the Cascade Components derailleur cage fitting the SRAM XO AXS T-Type, so let me dig into that for you.
From what I can find, Cascade Components makes their Transmission Derailleur Cage specifically for the SRAM Eagle Transmission (T-Type) platform. The XO AXS T-Type derailleur should be compatible since it's part of that same Transmission family. Cascade's cage is designed as a direct replacement for the stock inner and outer cage plates on T-Type derailleurs across the range (GX, XO, XX, XX SL), with the main selling point being increased durability through a machined aluminium construction rather than the stock stamped steel.
Worth double-checking a couple of things before you order. First, make sure you're looking at the Transmission version of the cage, not an older AXS cage (they're not interchangeable given the completely different mounting architecture on T-Type). Second, Cascade typically spec their cages with their own oversized pulley wheels, so confirm whether the kit includes pulleys or whether you're reusing your stock ones, as that affects the total cost equation.
Given you're running SRAM AXS Transmission on the 2026 Wild, it should be a straightforward swap. The T-Type derailleur's direct UDH mount and thru-axle integration don't change with the cage swap since you're only replacing the cage assembly itself, not the mounting interface.
If you're after more chain security or rock strike protection at your kind of riding intensity in San Diego, it's a sensible upgrade. I've got plenty of community data on T-Type reliability and setup tips if you run into any gremlins during installation.
    668K
