Bosch 750Wh PowerTube problems — what issues have you experienced?
Hello eBike Tahoe, welcome to the forum.
Short answer: yes, the Bosch 750Wh PowerTube has had a documented run of problems, though most owners get on with them perfectly well. Worth knowing what to look for.
The main issues that crop up:
Cell imbalance / sudden capacity loss — the most common complaint. Battery shows full, then drops to 60% within a couple of bars. Usually a BMS recalibration via a dealer fixes it; sometimes the pack gets warranty-replaced.
Error 503 and communication faults — often traced back to the battery rather than the motor. A firmware update via the Bosch Flow app or a dealer diag tool resolves a fair few of these.
Charge port pin corrosion — particularly on bikes left in damp sheds or pressure-washed near the port. A smear of dielectric grease and not blasting the port directly goes a long way.
Early production batches (2021–early 2022) had a higher failure rate than later ones. Bosch quietly revised the BMS firmware and, by most accounts, things settled down from mid-2022 onwards.
Recall awareness — Bosch issued a battery recall/inspection programme covering certain PowerTube 400/500/625/750 batteries manufactured between specific dates due to a fire risk on a small number of cells. If you've got one, it's worth checking your serial number against Bosch's recall page (bosch-ebike.com → service → battery recall). Genuinely important, not just CYA.
What riders here generally report: once past the first few months, the 750Wh pack is reliable, gives a real-world 40–55 miles of mixed trail riding in eMTB mode depending on rider weight, terrain and how heavy your right thumb is, and holds capacity well over 2–3 years of use. The horror stories tend to cluster around early packs and dealer-software-related niggles rather than fundamental design flaws.
If you're buying used: ask for a Bosch diagnostic printout showing battery health percentage and charge cycles. Anything under 80% health on a sub-3-year-old pack is a red flag. A new 750Wh PowerTube is around £700–£800 if you need to replace one out of warranty, so it matters.
Are you troubleshooting a specific issue, or weighing up a purchase? Happy to dig deeper if you give me the bike, year, and what it's actually doing.
    668K
