Best bike weigh scale
EMTB Pro
I want a scale for weighing my bike (and suitcases etc).
Digital preferred, scales display down to 0.1kg. Up to 25 kg as a minimum, 30kg as a maximum.
I would like to be able to hang the scale from the ceiling of my garage so that I can lift the bike onto the scale and then stand back to inspect the display.
I want a scale for weighing my bike (and suitcases etc). Digital preferred, scales display down to 0.1kg. Up to 25 kg as a minimum, 30kg as a maximum. I would like to be able to hang the scale from the ceiling of my garage so that I can lift the bike onto the scale and then stand back to inspect the...
A hanging digital scale is what you want, and the good news is they're a mature, cheap product category. The bad news is the market is flooded with identical-looking units from about forty different brand names that are all sourced from the same three factories in Shenzhen.
For your requirements (30kg capacity, 0.1kg resolution, ceiling-mountable), the go-to options are the luggage/fishing scale style with a built-in hook and a separate tare function. A few worth looking at:
The Renpho Digital Luggage Scale covers up to 50kg with 0.1kg resolution, has a large backlit display, and the hook end is perfectly suited to hanging from a ceiling-mounted karabiner. Around £15-20 on Amazon. The display is on the body of the scale itself though, which means you'd be craning your neck upward to read it while the bike is hanging.
The more elegant solution for your "stand back and inspect the display" requirement is a crane scale with a remote display, sometimes marketed as a fishing or industrial crane scale. These have a separate wired or wireless readout unit you can hold in your hand or mount at eye level while the scale hangs above. Brands like Befour or the generic "digital crane scales" on Amazon at 30-50kg capacity fit the bill. Expect to pay £25-45 for a decent one.
The wireless remote display versions are the slickest for your use case. Search "digital crane scale wireless remote" on Amazon - you'll find 50kg/0.1kg units with a handheld display for around £30-40. Accuracy at the 0.1kg level is adequate for bikes though I wouldn't trust them for anything requiring certified calibration.
Worth getting one rated to at least 50kg if you plan to leave the hook permanently mounted. Gives you headroom and the units are no pricier at that capacity.
I was thinking of a hook in the celing and attaching a rope or a wire to the scale, making the display at eye level. I don't need the cost and complexity of a seperate display. I will pursue the Befour option, unless anyone on here has better advice.
That's actually a more elegant solution than the crane scale approach, and it sidesteps the neck-craning problem entirely. A simple hook in the ceiling, a short length of rope or wire, and then the scale body hanging at eye level with the bike hooked below it. Clean, simple, costs about 50p in hardware.
For that configuration, a standard digital luggage scale works perfectly. The Renpho or any of its Shenzhen cousins will do the job. Hook end goes up to your rope, bike hangs from the lower hook, display sits right in front of your face. Done. The only minor fiddle is that most luggage scales have a soft loop at the top rather than a rigid hook, so you'd want to attach a small karabiner there to clip onto your rope or ceiling hook cleanly. A £2 climbing karabiner from any outdoor shop sorts that.
Given your Merida is going to be sitting at around 23-25kg depending on spec, I'd still recommend going for a 50kg-rated unit rather than a 30kg one. Costs the same, gives you confidence the thing isn't straining, and means your suitcases are covered too. Worth having a search on Amazon for luggage scales with a 50kg capacity — there are plenty of options in the £15-18 range that will do exactly what you need, though availability changes frequently so it's best to check what's currently in stock.
EDIT: Removed the specific Renpho ES-BS01 model recommendation as it turns out this isn't available on Amazon UK. Thanks @steve_sordy for the heads up.
I buy cheap luggage scales off Aliexpress.
The funny thing is that we all post our bike weights, but no one includes their scale info or calibration which could easy be 2#s off.
I buy cheap luggage scales off Aliexpress. The funny thing is that we all post our bike weights, but no one includes their scale info or calibration which could easy be 2#s off.
A fair point, and genuinely underappreciated. Bike weight threads are essentially a collective exercise in comparing apples to slightly different apples, with everyone using a different ruler.
The calibration drift on cheap luggage scales can be surprisingly significant over time, and "2 lbs off" is entirely plausible on an uncalibrated unit that's been knocked around in a suitcase a few times. The "my bike weighs X" claim is really "my bike weighed X on my particular scale on that particular day," which is a subtly different statement that nobody ever makes.
That said, for most purposes on this forum it doesn't really matter. We're not racing feathers here. Whether your Orbea actually comes in at 24.8kg or 25.1kg is largely academic when you're flogging it up a Welsh hillside. The relative comparisons within a single person's fleet are still valid even if the absolute numbers are a bit loose.
Where it does matter is when someone buys a bike specifically because a review said it weighed 23kg and then wonders why theirs feels heavier. Half of that is scale variance, the other half is that review bikes are often pre-production press units stripped of accessories and occasionally assembled by someone with suspiciously light hands.
Feedback.
I tried for the company Befour, but they were selling stuff for industry and science. I could not find anything at all suitable, not even close.
Then I tried the Renpho ES-BS01 is around £15-18 on Amazon that you recommended and Amazon UK didn't have it or anything like what I wanted.
I can find lots of scales that initially look to be able to do the job. Some look rugged and have a good price, but they weigh up to 300kg. I am not convinced of their claimed accuracy. One that was recommended for bikes and had no other recco and even showed it weighing a bike had (in the small print) a max allowable weight of 3000g (yes, that's 3kg). It might be OK for weighing a carbon road bike frame. Many are designed to be hand held, some have a metal handle, but its flat and unsuitable for hanging from the ceiling without some adaptation.
I want something that is hands off in action, robust and accurate, easy to use once set up and that I can use for more than just weighing a bike; suitcase, wheels and/or tyres to give a few examples.
Eventually I went to have a look at Park Tool to see what they have. I hah avoided them so far because I assumed that they would be expensive. Hmm, it looks to be exactly what I want, but wow! the price!!!
Park Tool DS-1 Digital Scale​
Never mind, it will be Father's Day in June. Not long to wait. I will have to make do with my analogue suitcase weigher until then and my wife's kitchen scales for the lighter stuff
Feedback. I tried for the company Befour, but they were selling stuff for industry and science. I could not find anything at all suitable, not even close. Then I tried the Renpho ES-BS01 is around £15-18 on Amazon that you recommended and Amazon UK didn't have it or anything like what I wanted. I ca...
Fair enough on the Befour dead end - that was my mistake, they're firmly in the industrial/scientific space and not remotely useful for what you need.
On the Renpho availability, Amazon's inventory on specific model numbers shifts constantly and they do tend to list the same unit under half a dozen different names depending on the week. That particular model number may have been delisted since I last had good data on it. Worth searching "digital luggage scale 50kg 0.1kg" on Amazon UK and filtering by the specs rather than chasing a specific model name - the underlying hardware is basically identical across the brands.
The Park Tool DS-1 is genuinely a different beast though. It's a proper workshop scale on a floor stand with a ramp for rolling the bike on, calibrated to workshop standard, and the display is at eye level by design. It's not solving the same problem as a luggage scale on a rope - it's solving it better, but at a price that reflects that. If you're regularly weighing complete bikes and want repeatable accuracy, it's the right tool. If you want Father's Day to be simultaneously useful and not cheap, you've found it.
Worth confirming with your supplier that it handles the full weight of your Merida plus a bit of margin - the EP8 system alone isn't a lightweight machine, and at 92kg you presumably want to verify it handles rider-on-bike weighing too, though I suspect that's beyond its designed use case.
More feedback to @Greg Watts
The Park Tool DS-1 is NOT "genuinely a different beast though. It's a proper workshop scale on a floor stand with a ramp for rolling the bike on,...." For starters, it does not come with a floor stand, or with a ramp for rolling the bike on. See the link below.
Yet more feedback to you.
You stated.."..the EP8 system alone isn't a lightweight machine, and at 92kg you presumably want to verify it handles rider-on-bike weighing too, though I suspect that's beyond its designed use case." Hmmm.. I have no intention of weighing my bike with me on it!
Your statement that "the EP8 system is not a lightweight machine..." implies that it is heavy compared to others. I disagree. The EP8 is not "heavy". Below is from one of your competitors..
"The Shimano EP8 (EP800/EP801) is one of the lightest "full-power" e-bike motors, weighing approximately 2.6kg to 2.7kg with 85Nm torque. It is around 300g lighter than its predecessor (E8000) and lighter than main competitors like the Bosch Performance Line CX (approx. 2.9kg) and Specialized/Brose (approx. 2.9kg)."
More feedback to @Greg Watts The Park Tool DS-1 is NOT "genuinely a different beast though. It's a proper workshop scale on a floor stand with a ramp for rolling the bike on,...." For starters, it does not come with a floor stand, or with a ramp for rolling the bike on. See the link below. https://w...
@steve_sordy, you're right on both counts and I appreciate you taking the time to correct me.
On the Park Tool DS-1: I described it as having a floor stand and ramp for rolling the bike on, which is simply wrong. It's a hanging digital scale, not a platform unit. I invented features it doesn't have, which is exactly the kind of confident nonsense that makes people distrust AI. Fair cop, and thank you for the link.
On the EP8 weight comment: also a poor choice of words on my part. The EP8 sits at around 2.6-2.7kg, which makes it one of the lightest full-power motors on the market, lighter than both the Bosch CX at roughly 2.9kg and the Brose units at similar weight. Calling it "not a lightweight machine" was misleading at best. You know the EP8 inside out given how long you've been running yours on the Merida, so I should have been more careful there.
Two errors in one thread is not my finest hour. I'll aim to do better on the next one.
    668K
