Alternatives to a Back Pack
Ballynoes
13
Did a quick search, but still didn't find a definitive answer.
My back pack when I go out into the hills is getting heavier, as I take quite a bit of kit with me.... well you have to when out on your own, in the middle of nowhere.
Anyway, now I have a drone with me as well, it's all getting a bit cumbersome.
Question is, I am looking for a suitable Panier system, to put the kit into, and then just a small camel back or the likes.
Full sus EBike, so the travel on the suspension has to be considered.
Any one done this sort of thing before - the Old Mountain Man racks look good, but not sure how this will all effect the ability to remove the rear wheel in case of a puncture etc. And if the rear suspension will cause any issues. Also looking for a bag system which will come on and off in seconds, so when I get anywhere I can take it off easily.
TIA
Tim1023
665
591
Hamburg, Germany
TIA
The Old Man Mountain rack is solid and allows your rear suspension to work (mine is on a Levo). And yes, it will be a pain should you want to repair a puncture on go. How often do you get them? Tubeless?
For more discussions on the topic, see:
Ballynoes
13
Thanks for the reply, think I will go with something like these.
that way I can take 1, 2 or none, depending on the ride for the day.
Also they won't interfere with suspension, or cause issues taking the wheels off.
Binhill1
🍊 Tango Man 🍊
Mar 7, 2019
3,559
5,515
TIA
Depending on size you need etc a handlebar bag is an option. But if you have a drone it's probably too small. Beauty of a rucksack is your body will cusion most of the bumps a rear rack or bag won't.
6,699
5,173
A waist bag will carry a drink bladder plus some tools etc......that would reduce the need for a big backpack. Backpacks also vary greatly in terms of how well they are secured on your back...keep in mind most are for hiking and not that comfortable for either the angle of your back when on a bike or the roughness of the ride. The smaller the back pack the better really. Camelback make some good backpacks usually with drinks bladder compartments but if you already have a bladder in a waist pack then they offer a good amount of space for other kit.
Jackware
Fat-tyred Freakazoid
2,138
2,342
Lancashire
I found a waist bag bounced up and down too much, and have reverted to a small backpack, but it has decent waist and chest straps.
Binhill1
🍊 Tango Man 🍊
Mar 7, 2019
3,559
5,515
Bumbags were the fashion in 80s , they are ok with minimal amount in them. I got a good rucksack from mountain hardware £14 pvc it was for caving trips.. I tried it on bike its bigger than I need but it carries so well I've never used anything else since I got it.
edruid
86
42
Gloucestershire
I have this system front and back and it's good.
Would not recommend it for downhill rock garden but for trail is fine.
Binhill1
🍊 Tango Man 🍊
Mar 7, 2019
3,559
5,515
Used a Blackburn rack for years on my hill bike just going up the Glen to start of hill climb. As u say cant bomb back down the hill with all the weight.
Binhill1
🍊 Tango Man 🍊
Mar 7, 2019
3,559
5,515
Agreed regarding the rear rack.
The pannier rack could be a good alternative to something like the Ortleib fork pack, as it goes on the rear, which I would prefer over carrying something on the fork.
Depends where you are going terrain wise , and how much you are carrying. I have carried quite a lot on rear rack with panniers , not on a Ebike but a bike is a bike. I've also used a big rucksack not recommended .
563K
