pivot shuttle amp'd with avinox m2s Team XX Eagle Transmission
galanakop
Pivot shuttle amp'd with avinox m2s and specifically the Shuttle AMP'd Team XX Eagle Transmission.It's a bike around 15k and I'm interested in your opinion. thanks
You should read through this thread, it has some riding impressions.
You're asking about the Team build which I can't comment on, I have the Pro which seems the sweet spot since the new Zeb is so good.
I'm still in the honeymoon phase with only a couple hundred miles so far, but my opinion is that if you can only own one emtb this is the one. Make sure during setup that your LBS bleeds the Mavens correctly, replace the generic saddle with your favorite and go ride it. If you ride extra hard or fast in very rocky terrain, replace the tires with something that has gravity casings as the stock tires seem to be too lightweight for an emtb. I've seen 3 reviewers so far that got flat tires.
There are better longer travel bikes specializing in DH riding, but the AMP'd is good at almost anything you can throw at it and most importantly it's very fun to ride. It draws me out of the house and onto the trails almost daily.
Doesn't cost enough, they should fix that.
JK, it's a sick bike, can't go wrong with that choice.
