Levo Gen 2 300psi in Float X2 normal for a 88kg rider? Levo gen2
ebikeZA
278
138
Cape Town
So I put on a X2 on my gen 2 levo and have to pump the Shox to a tad over 300psi to get close to the 30% sag.
is is normal for this Shox to be so high ? bit worried as the stated max is 300.
will volume reducers help with this ?
Paulquattro
1,836
990
The Darkside
Hi
300+ is as you noticed to high for an X2 and volume spacers only increase ramp up not initial sag
You can thou put spacers in and run a bit more sag with more ramp up to prevent the shock bottoming out
I have found X2s do like a bit more pressure than most shocks.
RickBullotta
1,760
1,502
Unfortunately the X2 runs quite high pressures. Did you cycle the shock every 25 psi as you filled it to equalize the negative chamber?
A Float X might be a better option. You'd be at about 220-225 psi (max is 350).
521K
