For Sale (PARTS) 2025 Rockshox Super Deluxe Ultimate RC2T HBO C2 / XL Linear Air Can £395
Apr 14, 2020
125
35
Surrey, UK
Brand new boxed, this is the very latest just released C2 version with updated piston / damping, this version has the fixed internal HBO, also included is a Rockshox XL Linear air can if you want a plusher feel or your bike has a very progressive leverage curve. According to Sram this air can bridges the gap between the Super Deluxe and the Vivid.
Has had upgraded nylon bushes.
FEATURES 2025
NEW High-flow main piston reduces High Speed Compression damping, eliminating hang-ups and allows the wheel to easily get out of the way on hard impacts.
RC2T damper, the most tunable shock damper we’ve ever made, offers independent High Speed and Low Speed Compression adjustments, eliminating “cross-talk” so you can tune your shock to exactly how you want it to perform.
RC2T damper offers Rebound adjustment, independent High and Low Speed Compression adjustment, and an easy-adjust Threshold lever for added pedaling efficiency.
DebonAir+ air springs maximize fine-tuning potential, allowing you to tune your air volume with Bottomless Tokens to perfectly match your bike, desired ride feel, and the trail ahead.
The optional Hydraulic Bottom Out kicks in to restrict the flow of oil within the last 20% of travel, offering a soft hydraulic cushion that reduces harsh bottom out.
14-15 clicks of Rebound adjustment offer a wider range of tunability and accommodate more rider types.
Castled bottom out bumper reduces harsh bottom-out, leaving extra room for the bold to go big.
Separate and independent Open and Threshold pistons tuned exactly for your ride.
Top-of-the-line Maxima Plush Dynamic Suspension Lube reduces friction to help maintain traction.
IMG_9786.jpg IMG_9787.jpg IMG_9788.jpg IMG_9789.jpg IMG_9790.jpg IMG_9791.jpg IMG_9792.jpg IMG_9793.jpg IMG_9794.jpg IMG_9795.jpg IMG_9783.jpg
125
35
Surrey, UK
If you don't want the XL Air Can I'm happy to negotiate on price, also I have quite a lot of brand new fitting kits so may be able to help out if you know what size bushing your bike uses.
537K
