For Sale (BIKE) 2025 Mondraker Crafty RR S Large: €9599
Pritchi83
Dublin, Ireland
Bike / Product Year: 2024
Manufacturer: 2025 Mondraker
Model: CRafty RR S
Size LArge
Asking Price: €9599
Location Ireland
Description Brand new 2025 Mondraker Crafty RR S in large. Just built out of the box. 0 miles
Stunning bike
Frame​
Crafty Stealth Air full Carbon, Updated Zero Suspension System, Mullet, 150mm trail, Forward Geometry, Removable internal battery, Boost 12x148mm rear axle, Tapered head tube, Monobloc one-piece upper link, HHG internal cable routing, Sealed bearings capacity max., 15 mm oversized axle, exclusive plastic engine guards.
Size​
L: 460 mm
Rear shock​
Fox Float-X Factory Kashima EVOL LV, 185x55 mm. Adjustments: 2-position compression lever, low-speed compression, low-speed rebound, air preload. High-mount trunnion, 30x8 mm lower bushings.
Fork​
Fox 38 29 Float GRIPX2 Factory Kashima, 160mm, tapered steerer, 15x110mm Kabolt Boost axle, 44mm offset. Adjustments: high and low speed compression, high and low speed rebound, air preload.
Headset​
Acros custom ZS56/ZS56, 1-1/8", 1.5" head tube, internal cable routing, sealed cap without blocklock.
Stem​
ONOFF S6 30mm 0º, 6061+ CNC forged alloy, 31.8mm bore.
Bars​
ONOFF S6 1.0 Carbon, camber: 25 mm, width: 800 mm, 8º bend, 5º rise, 31.8 mm bore. Size L and XL: camber 1.5.
Grips​
ONOFF Desert Pro, CNC lock-on, 135mm. Thicker size for L and XL.
Seat post​
Fox Transfer Factory Internal Kashima, Adjustable Trail, 31.6mm Diameter, Size S: 95mm - 120mm, Size M: 125mm - 150mm, Size ML/L: 155mm - 180mm, Size XL: 185mm - 210 mm.
Saddle​
Ergon SM-10.
Front brake​
Sram Maven Silver, 4-piston caliper 18 and 19.5 mm, Centerline 200 mm, IS 6-bolt single-piece disc, sintered metal on steel pads.
Rear brake​
Brake levers​
Sram Maven Silver, SwingLink and shifter pivot bushings, tool-free reach adjustment.
Rims​
Mavic E-Deemax S 29, 30mm internal width, welded Maxtal, PFP, tubeless, 28 spokes.
Spokes​
Mavic double-butted straight spokes, contactless lacing.
Front hub​
Mavic , Boost 15x110 mm, IS 6 holes.
Rear hub​
Mavic , Boost 12x148 mm, Ratched ID360 system, IS 6 bolts, XD freehub.
Front tire​
Maxxis Minion DHF 29x2.6", tubeless compatible, 3C MAXX TERRA rubber, EXO+ protection, 120TPI, folding bead.
Rear tire​
Maxxis Minion DHR II 29x2.6", tubeless compatible, 3C MAXX TERRA rubber, EXO+ protection, 120TPI, folding bead.
Cranks​
Race Face Aeffect -R ebike, 160mm.
Chain Ring​
Sram X-Sync 2 Eagle 34T, T-Type, Steel, Narrow Width, 104 BCD CL55.
Chain​
Sram GX Eagle T-Type, 12 speed, Powerlock.
Rear derailleur​
Sram X0 Eagle AXS, T-Type, 12 speed.
Gear Shift​
Sram Eagle AXS Pod MMX, 12 speed.
Cassette​
Sram XS-1295, 10-52 teeth, T-Type, 12 speed.
Engine​
New Bosch Performance Line CX Cruise (25 km/h) GEN4 SMART SYSTEM (BDU384Y).
Battery​
Bosch Powertube 600Wh.
Screen​
Purion 400 / Bosch Mini Remote / Bosch System Controller.
Weight​
22.8 kg
    673K
