Turbo Only
Bike / Product Year: 2024
Manufacturer: Cannondale
Model: Moterra Neo SL 2Tiger Shark
Size XL
Asking Price: 3250.00
Location Horsham, West Sussex, UK
Description Take a look at my Cannonade Moterra Neo SL 2 2024 X Large Tiger Shark.
Purchased in June 2024 and has embarrassingly only covered 362km. When I purchased the bike. I took off all the components, and fitted different ones. The only parts that have been used are the frame, rear shock and motor system (motor, battery remote etc). I took the handlebar display off too, so that hasn't been used either.
I fitted protective tape to most of the frame when it was new, and removed it as I was getting the bike ready to sell, so it has very few signs of wear. There is a row of small marks/scratches on the inside of the non-driveside seat stay above where the rear calliper fits.
One of the original Cannodale grips was broken from new, so it has a set of Burgtec Bartender Pro grips on instead.
The charger came with an EU plug, which I have cut off and fitted a UK plug to.
The bike is running great, and I haven't had any issues with the frame or motor system in the time that I used them, but the battery was replaced as a preventive measure, and is the latest version.
Collection only from Horsham West Sussex.
Frame - Moterra SL, Series 1 Carbon construction, 150mm travel, Proportional Response Tuned Suspension, FlexPivot Chainstay, direct mount internal battery, engineered plastic skid plate, 55mm chainline, DirectLine internal cable routing, 29” FlipChip, 148×12mm Maxle thru-axle, UDH hanger, 200mm native post mount brake, 1-1/8” – 1.5” tapered headtube, angle adjust headset - Used, 362km and working fine
Fork - Fox Performance 36, 160mm travel, Grip Damper, 3-position adjust, 15×110mm Kabolt thru-axle, tapered steerer, 44mm offset - Brand new
Headset - Acros Adjustable Angle (1.2°) - Used, 362km and working fine
Rear Shock - Fox Float X Performance Elite, 2 pos adj, EVOL LV, 210×55mm - Used, 362km and working fine
Drive Unit - Shimano EP801, 85Nm, Custom Tuned, Eco, Trail 1, Trail 2, Boost Modes - Used, 362km and working fine
Battery - Custom 601Wh battery - Brand new latest version
Charger - Custom 4A
Display - Shimano SC-EM800 Cycle Computer, Bluetooth LE Compatible - Brand new
Rear Derailleur - Shimano XT 12 speed - Brand new
Shifter - Shimano Deore M6100, 12-speed - Brand new
Chain - Shimano Deore 6100, 12-speed - Brand new
Crank - e*thirteen e*spec Plus, 165mm, 34T - Brand new
Cassette - Shimano Deore 6100, 10-51, 12-speed - Brand new
Brakes - Magura MT5 4 Piston, 203mm Magura MDR-P rotors - Brand new
Rims - WTB KOM Tough i30, 30mm inner width, TCS tubeless ready - Brand new
Spokes - DT Swiss Champion - Brand new
Hubs - Front Formula DC-71132h, 15×110mm / Rear DT Swiss 370 Hybrid, 32h, 12×148mm - Brand new
Tyres - Front Maxxis DHF, 29×2.5 “, 2C, EXO, tubeless ready / Rear Maxxis Dissector , 27.5×2.4”, 2C, EXO, tubeless ready - Brand new
Handlebar - Cannondale 3 riser, 6061 Alloy, 25mm rise, 8° sweep, 4° rise, 800mm - Brand new
Stem - Cannondale 1, 6061 Alloy, 35.0, 40mm, 0° - Brand new
Grips - Burgtec Bartender Pro Greg Minnaar - Brand new
Saddle - Fizik Terra Ridon X5, 145mm, Wingflex, S-Alloy Mobius rail 7×7mm - Brand new
Seatpost - Cannondale DownLow Dropper, internal routing, 31.6, 170mm - Brand new
Pedals - Not Included
