Christurbo
Bike / Product Year: 2023
Manufacturer: Specialized
Model: Kenevo Expert
Size S3
Asking Price: 3150
Location Llandegla / Wrexham
Description I have for sale my Kenevo Expert E-Mountain Bike, this is a unique sale as most of the components are brand new.
I bought the full bike just for its frame which I built upon but only used rarely (just 44 charge cycles). I have decided to put it back to standard with the original brand new parts, so effectively this looks and feels like a brand new bike as the frame was Invisiframed from new, ceramic coated and stored in a heated and dry environment. The wheels even have the plastic protective film as they have never been used.
It comes with original case, manuals, etc.
I have included some upgrades in the build for the new owner see spec below.
Please note I also have all the parts I used to upgrade the Kenevo for sale.
Collection only - Based near Wrexham/Llandegla
Used parts:-
Frame: Specialized Kenevo Oak Green, Size S3, Turbo Full power 2.2 motor and TCU 2 display, 180mm travel.
UI/Remote: Specialized MasterMind TCU, percentage of remaining charge, 120 possible display configurations, MicroTune assist adjustment, over-the-air updates, ANT+/Bluetooth®, w/Handlebar remote.
Battery: M2 Series, 700 watt hour, 100% health, 44 charge cycles, 569 miles.
Brakes: Magura MT7 Pro 4 pot piston calipers, Gold rings, Magura lines, Shimano Saint Levers, Galfer purple pads, 220mm discs.
Saddle: ErgonSM Enduro Saddle
Charger: Custom charger, 42V4A w/ Rosenberger plug
New parts:-
Rear Shock: RockShox Super Deluxe Select Plus, 230 x 62.5mm
Fork: RockShox Boxxer Select RC, 27.5, DebonAir, 20x110mm Boost™, 35mm chassis, 180mm of travel
Stem: Descendant 35mm Direct Mount Stem, 50mm length
Handlebars: Specialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 30mm rise, 800mm, 35mm clamp
Grips: Deity, Knuckleduster, Black
Rear Derailleur: Sram X01 Eagle, 12-speed
Shift Levers: SRAM XO1 Eagle trigger, 12-speed, single click
Cabling: Jagwire pro
Chain: SRAM GX Eagle, 12-speed
Crankset: Praxis Carbon M30, custom offset, 160mm
Chainrings: SRAM X-Sync Eagle, 104BCD, 32T, steel
Rims: Roval 27.5" Alloy DH, 28mm internal width, 32h, tubeless ready
Front Hub: Alloy, sealed cartridge bearings, 20x110mm, 28h
Rear Hub: DT Swiss 370, 6-bolt, 12x148mm thru-axle, 32h
Spokes: DT Swiss Industry
Front Tire: Butcher Grid Gravity 2Bliss Ready T9, 27.5 x 2.6"
Rear Tire: Butcher Grid Gravity 2Bliss Ready T9, 27.5 x 2.6"
Inner Tubes: Presta, 40mm valve
SeatPost: OneUp, Dropper Post-V2, MMX lever, 34.9 (150mm)
Seat Binder: Alloy, 38.6mm
SWAT: Specialized Z-Cage, Multi-tool.
