2023 Giant Trance X2 with CYC Photon motor
Kiwiscoot
28
8
Christchurch, New Zealand
OK Here are some photos of my build using my 2023 Giant Trance X2.
Motor is the 1200W 110nm Cyc Photon - https://www.cycmotor.com/photon
Battery is a 48V 25Ah (1200wh) battery with Samsung 21700 50e cells in a leather frame bag. Some waterproofing and securing of main battery connector still needs to be done.
I have done 700kms on the motor with a 36V battery. I have an 2021 Giant Trance E+ 3 Pro for comparison and this build is lighter and feels more like an analogue bike than an ebike. The Trance E+ 3 Pro feels quite heavy on the trials in comparison. The Cyc motor is not as smooth at the start as the Giant Syncdrive Pro but once going it feels pretty much the same.
The build is pretty straight forward. I run a 34 tooth chainring with the standard cassette and can reach a speed of 42kph in Race mode (1200w) before I spin out. Most of the time I run it in Street mode (250W) which is plenty of power. All data from the motor is available on the control panel e.g. controller temp, motor temp, watts motor is running at, motor rpm, rider rpm, rider watts, etc. The phone app Cyc Control is very good and most parameters of the motor can be changed, like assist start delay, amount of assist, etc.
All in all a pretty good if somewhat pricey option to convert that old analogue bike to an emb.
Disclaimer - I have no affiliation with CYC, just a customer who bought this with his own money and sharing his experience.
20250212_161857.jpg 20250212_161907.jpg 20250212_161925.jpg 20250212_162030.jpg 20250212_162036.jpg 20250212_162042.jpg 20250212_162047.jpg 20250212_162056.jpg
Guitarfink
Hi, looks a very nice set up. I have the same frame and am considering fitting a photon. The shape of the frame does not look as if you can rotate the motor forward very far, I wondered if you could advise how much clearance you have to the ground from the bottom of the motor? Have you found clearance ok for trails? Many thanks
Kiwiscoot
28
8
The bottom of the 34t chainring is actually slightly lower to the ground than the Photon. The Photon will hit first but then the chainring will too, so even if the Photon could sit higher you will have issues hitting an object that high.
One thing I'd change in my setup if I were to do it again, I'll get the shortest crankarms that they sell with the Photon. I will change mine as I get a lot of pedal strikes. Redoing the suspension setup running higher back shock pressure after the conversion did fix that to an extent.
The battery setup is great - 65% battery capacity left after 130km with 1000m elevation gain riding mostly level 1 and 2 on Street mode (Canada mode - 5 levels set)and the occasional level 3 on the very steep bits.
This setup was built to do the Great rides of New Zealand
Guitarfink
Hi thanks very much for the info much appreciated. I will probably stick with the longer crack arm as its the same size as the current one fitted. Battery use sounds very good. Frustratingly the Photons are Currently out of stock in China and no date as to when they will be back. So will have to wait a while before upgrading!
Kiwiscoot
28
8
I see now that my Cyc Photon came with 175mm crank arms however the OEM Giant crank arms are 170mm. Cyc has only got 175mm and 165mm options. Personally I would go for the 165mm ones as the motor compensates for the difference in length and less pedal strikes are just better overall for ride enjoyment. I see a lot of top tier emtbs have 160mm crank arms with less powerful motors.
I got mine from Venture here in NZ last year. Might be an option for you to get one from here. I have no affiliation with then except for being a satisfied customer. My battery was from them too and I see they do combo deals too. You can also order the 34 tooth chainring should you want to go with that as they had them in stock when I ordered mine. Just a thought.
I must say you will not be disappointed in the conversion.
571K
