Sold 2022 Trek Rail 5 625w Large: £2,000
shredder
Fife
Bike / Product Year: 2022
Manufacturer: Trek
Model: Rail 5
Size Large
Asking Price: £2,000
Location Burntisland, Fife
Description I’m selling my Trek Rail 5 gen 2, 625w large size eBike. It was purchased in March 2023 from Trek Edinburgh and has been used sparingly. 1560km on the clock, well maintained, hand washed (never jet washed, or hosed), unused in the last 6 months as I’m back on a non-electric MTB and the battery was always stored indoors.
I upgraded the fork to a 170mm Marzocchi Bomber Z1 air (can take a coil), the brakes to Shimano Deore M6120 and the tyres to Bontrager SE6 (front) and SE 5 (rear) – both tubeless. The bike was Invisiframed from new and has minor scratches as expected of a mountain bike. Included in the sale are two keys, charger, neoprene battery cover and front mud guard. It’s an amazing bike for ups and downs and hasn’t given me any trouble whatsoever.
Any questions please let me know. Can provide proof of purchase.
Frame:
Alpha Platinum Aluminium, Removable Integrated Battery (RIB), tapered head tube, Control Freak internal routing, magnesium rocker link, Motor Armour, Mino Link, ABP, Boost148, 12 mm thru axle, 150 mm travel
Fork:
Marzocchi bomber Z1 170mm (upgrade)
Wheels:
Hub front - Bontrager sealed bearing, alloy axle, 6-bolt, Boost110, 15 mm thru axle
Hub rear - Bontrager alloy, sealed bearing, alloy axle, 6-bolt, Shimano 8/9/10 freehub, Boost148, 12 mm thru axle
Skewer rear - Bontrager Switch thru-axle, removable lever
Rim - Alex MD35, tubeless compatible, 32-hole, 35 mm width, Presta valve
Spokes 14 g stainless steel, black
Tyre - Bontrager SE5, (upgrade)
E-system:
Battery - Bosch PowerTube 625 Wh
Charger - Bosch compact 2A, 100–240V
Drivetrain:
Shifter - Shimano Deore M6100, 12-speed
Rear derailleur - Shimano Deore M6100, long cage
Crank - E*thirteen E*spec Plus, 165 mm length
Chainring - E*thirteen, 34T, steel
Cassette - SunRace CSMZ800 11-51, 12-speed
Chain - Shimano Deore M6100, 12-speed
Pedals not included
Components:
Saddle - Bontrager Arvada, steel rails, 138 mm width
Seatpost - Bontrager Line Dropper, 125 mm travel, internal routing, 31.6 mm, 395mm length
Handlebar - Bontrager alloy, 31.8 mm, 15 mm rise, 750 mm width
Grips - Bontrager XR Trail Comp, nylon lock-on
Stem - Bontrager Rhythm Comp, 31.8 mm, 0-degree, 50 mm length
Brake - Shimano 4-piston hydraulic disc, Deore M6120 (upgrade)
Brake rotor - Shimano RT76, 6-bolt, 203 mm
    673K
