Levo Gen 3 2022 kenevo comp vs alloy comp price difference
Teghogh
Socal
I’m a bit confused on why the comp alloy is priced at 7500 where kenevo comp is at 6k.
They are seemily compatible in terms of spec. Shocks and forks have longer travel on kenevo. Same brakes same drivetrain.
The only difference is the extra 200wh battery capacity as well as the muller set up that is missing on the kenevo. What am I missing here? Th ere is no way such small upgrades should be priced 1500 higher. For the extra 500 from base alloy you get code r brakes much better shocks and much better gx set up as upposed to sx. This makes the kenevo a no brainer in the line in my opinion
