For Sale (BIKE) 2022 Intense TAZER MX PRO 2023 L/XL: €8199
Pritchi83
Dublin, Ireland
Bike / Product Year: 2022
Manufacturer: Intense
Model: TAZER MX PRO 2023
Size L/XL
Asking Price: €8199
Location Dublin
Description
Brand new just out of the box. Will ship anywhere​
Frame: Corbon fiber front and rear triangle with internal cable routing
Fork: Öhlins DH38 Race fork, dual crown, 170 mm travel, air spring system
Shock: Öhlins TTX22M coil, 155 mm travel, high/low speed compression adjustment, rebound adjustment - spring 480 LB (S/M size) 548 LB (L/XL size)
Motor: Shimano Steps EP8
Battery: BT-E8010 for Steps, 504Wh, Battery lock with 2 keys
Display: Shimano Steps LCD, Bluetooth compatible
Brakes: Magura MT7 with 203 mm Storm HC rotors front and back
Shifter: Shimano SLX 12-speed
Derailleur: Shimano SLX 12-speed
Cranks: E*thirteen E*Spec with 34 tooth chainring, 165 mm length
Cassette: Shimano Deore 12-speed 11-51 tooth
Chain: Shimano Deore 12-speed
Wheelset: Ethirteen E*spec alloy rim 30 mm rim width x 29” front / 35 mm rim width x 27.5” rear
Hubs: INTENSE E-specific alloy hubs
Tires: Maxxis Minion DHR II Maxx Terra 3C EXO+ 29” x 2.60” Front / 27.5” x 2.8” Rear
Seatpost: INTENSE Recon Dropper Post - 125 mm length (S/M) 150 mm length (L/XL)
Saddle: SDG Bel-Air
Handlebar: Intense Fatbar 35, 800mm width, 30mm rise
Stem: INTENSE Direct Mount 35 mm OD x 50 mm length
Grips: ODI Elite Flow
Weight: 23,9 kg / 52 lbs 11 oz (size S/M, tubeless, with pedals)
Wheelbase: 1235 mm / 48.6" (size S/M), 1294 mm 51" (size L/XL)
    675K
