S-works also has carbon chainstay while comp has alloy chainstay...
Yeah it is all in the decal.There is an actual spec for S-works carbon.
Not the same as other models, but probably minuscule difference, in the long run.
Must be a full moon or something, the amount of false information popping up on this forum the past few days is amazing.
Look, I get that everyone (every s-works owner) would like the s-works to be different to justify the price tag but unfortunately with the Levo's it just isn't.
Nothing with the 2022+ models, the older models used the Fact 9 carbon but all the newer ones are all Fact 11 carbon.Anyone know what the differences between the frames besides color?
Just talking about the frame, and not any of the components that we add to them to make it into a complete bicycle.Um, not exactly. The S-Works frame comes with a Fox Factory X2 rear shock vs the Carbon Comp's Float X Performance rear shock.
Umm FFS. Frame…..not suspension.Um, not exactly. The S-Works frame comes with a Fox Factory X2 rear shock vs the Carbon Comp's Float X Performance rear shock.
Umm FFS. You can't buy the f*cking frame without rear suspension. Just stop.Umm FFS. Frame…..not suspension.
You can only buy an s works frame. No other can be purchased so cannot be compared in its entirety so your comment about the shock being different is irrelevant.Umm FFS. You can't buy the f*cking frame without rear suspension. Just stop.
2022 Comp carbon is all carbon composite, including the chainstay.S-works also has carbon chainstay while comp has alloy chainstay...
my 2022 comp carbon is all carbon composite , including the chainstayS-works also has carbon chainstay while comp has alloy chainstay...
