For Sale (BIKE) 2021 Rockshox Super deluxe select plus 205x65: 250
thebarber
Norfeast
Bike / Product Year: 2021
Manufacturer: Rockshox
Model: Super deluxe select plus
Size 205x65
Asking Price: 250
Location Durham
Description Rockshox super deluxe select plus
Rode once around the doors then replaced with fox x2
£250 + post
Hey @thebarber, what is the compression tuning?
It should be printed below the serial number after mounting size / stroke length.
VFH7-F62N-KQRX-LNRLR
Hey, sorry but that's not what I've asked about. I mean this: below the serial number there should be another line of text that tells the mounting size x stroke and after that there are two letters (possible values are H, M, L) or two groups of letter and digit. In your case it should be 205x65 XY (i.e. 205x65 LL, or 205x65 ML or 205x65 ML1 etc.). I assume that RockShox uses this pattern on all their recent rear shock models, does your shock have something similar printed below the serial number?
My Deluxe damper (which I want to upgrade, that's why I'm asking) is marked this way and has the following: 205x65 LL, that means it has been internally tuned for low compression damping and low rebound damping. These values are important because the frame manufacturers pick the rear shocks internal tunes depending on frame design (rear linkage ratio / travel curve etc). So that's why I want to know that XY part, because I want to match my current shock's internal tune.
    673K
