2019 to 2021 Turbo Levo 2020 Turbo Levo shock upgrade
rusuovidiu10
Romania
Hello!
I own a 2020 Turbo Levo base model and plan on upgrading some of the less suited parts for this bike. This inculdes the rear RS deluxe select shock.
So, I wonder:
  1. Does a 210X55 fit? Does it increase rear travel? (bike comes stock with 210x52.5 and is size M)
  2. Will fitting the new shock with no custom tune on it negatively impact suspension performance, instead of improving it? (stock shock has Specialized's RX trail tune from factory)
Thank you!
James_C
362
177
Kent, UK
55 gives you 158 travel I’m told ( just put one on) so yes you can use it
Why not just sell the whole bike and get a comp though , better battery brakes and gears, and a lyrik, all worthwhile
rusuovidiu10
Romania
Thanks for your reply! Does your new shock have any custom tune on it?
You have a point there, but it might be a tad bit too late for this to happen, since I already replaced the brakes and front suspension:)
James_C
362
177
Kent, UK
No. it’s a Ohlins ttx coil with a 607 spring
463K
