For Sale (BIKE) 2020 Cube Stereo Hybrid 160 HPC SL 18 inch: £2600
Jeffw
North West
Bike / Product Year: 2020
Manufacturer: Cube
Model: Stereo Hybrid 160 HPC SL
Size 18 inch
Asking Price: £2600
Location Wigan
Description One owner, Original receipt available
Size 18" (Medium)
Bosch CX4 Motor. 85nm (fitted as a warranty replacement August 2021)
625w Powertube battery
Charger upgraded from 2amp slow charge to a 6amp fast charge
Bosch Purion display
FORK RockShox Lyrik Select Charger RC, 15x110mm, eMTB Approved, 170mm
SHOCK Rock Shox Deluxe Select+, 205x60mm, Trunnion Mount
SEAT POST CUBE Dropper Post
Tyres upgraded to Michelin E-Wild (27.5 front and rear), running tubeless
Pedals: Nukeproof Neutron EVO
Grips: ODI Lock on
Brakes: Magura MT Thirty, Front 4-Piston/ Rear 4-Piston, Hydr. Disc Brake (203/203)
The bike is fitted with a Standup metal plate to protect the motor guard
Well maintained (cleaned and lubed after every ride)
Frame and headset Bearings replaced (Feb 2022) as part of routine servicing by bike shop (receipts available)
New gear cable inners and Freehub serviced (receipts available)
Forks serviced (July 2022)
Sale includes four sets of brake pads
Bike owned from new
Some scratches due to wear and tear
Hi - interested in the bike & have a few questions;
How many miles since motor changed (approx)
How many battery charge cycles (approx)
What condition are the 'consumables' (chain, brake pads, etc)
Can you confirm model of the drivetrain
Any particular reason for sale
Hi Maxi
The motor was replaced under warranty in August 2021. The display shows 802 miles
I sometimes ride twice a week, other times perhaps twice a month. I reckon about 40 charges since the motor was changed
The chain was put on in Feb this year and a new cassette was fitted also
I change the brake pads every few months, so always have a stock of them in that i get from Uber. I currently have 4 sets spare, they will go with the bike
pedals - Nukeproof Neutron EVO
cranks - ACID E-Crank, 36T, 165mm (stock)
chain - KMC
cassette - SRAM NX Eagle PG-1230 12 Speed Cassette
derailleur - Sram NX Eagle™, 12-Speed (stock)
Headset - a sealed headset unit was fitted in April 2021 after the stock headset bearings had water ingress
The full spec is available here (those marked 'stocl' above came with the bike)
Reason for sale: No particular reason. Simply made one of my regular visits to my LBS ( a good friend works there) for a browse and mentioned they had a 2022 160 in stock, with the ZEB Ultimate forks. Appealed, so went for it
Hope this helps
Thanks for the quick & comprehensive reply. This sounds ideal for me as my first foray into eMTB (been riding an old 29er with outdated geometry) as my knees give me grief on the hills. As a new member, I don't think I can DM you, but would you / bike be available Saturday morning for a view / ride ?
    675K
