RichTose
- Mar 8, 2026
- 2
- 0
Bike / Product Year: 2019
Manufacturer: Trek
Model: Powerfly 7 LT
Size Medium
Asking Price: £2099
Location Chandlers Ford, Hampshire
Description 2019 Trek Powerfly LT 7 Plus is a highly regarded, long-travel (160mm front/150mm rear) enduro eMTB featuring a 500Wh Bosch PowerTube battery and Performance CX motor. It excels in climbing, handling, and stability, with many reviewers praising its balanced, confident feel on technical terrain, despite being heavier than some competitors. (AI Review)
Frame - Alpha Platinum Aluminium, ABP, Removable Integrated Battery (RIB), EVO link, tapered head tube, Knock Block, internal derailleur and dropper post routing, G2 Geometry, Boost148, 150 mm travel. Rear triangle (replaced under warranty after bearings ceased - Sept 24)
Fork - RockShox Yari RL, DebonAir, Motion Control RL damper, tapered steerer, Boost110, G2 Geometry w/51 mm offset, 160 mm travel
Rear shock - RockShox Deluxe RL, 205x57.5 mm (Last serviced Sept 24)
Wheels - Bontrager Line Comp 40, Tubeless Ready, 54T Rapid Drive, Boost110 front, Boost148 rear, tubeless strips included, valves sold separately
Tyres - Tubeless Continental Argotile (NEW NOV 25)
Shifters - Shimano Deore XT M8000, 11 speed
Rear derailleur - Shimano Deore XT M8000, Shadow Plus (NEW Jan 26)
Crank - Race Aeffect, 15T w/chain guard
Cassette - Shimano SLX M7000, 11-46, 11-speed (NEW Jan26)
Chain - Shimano HG600, 11-speed (NEW Jan 26)
Pedals - New Jan 26
Saddle - Bontrager Arvada
Seatpost - Dropper post, 31.6 mm, internal routing
Handlebar - Bontrager Rhythm Comp, 31.8 mm, 15 mm rise, 780 mm width
Bontrager Rhythm Comp, Knock Block, 31.8 mm clamp, 0-degree
Head set - Knock Block Integrated, sealed cartridge bearing, 1-1/8˝ top, 1.5˝ bottom
Brake set - Shimano MT520 4-piston hydraulic disc
Battery - Bosch PowerTube 500 Wh
Bosch Purion Display
Motor - Bosch Performance CX ( Replaced under warranty July 22, serviced )
Weight - M - 23.59 kg / 52 lbs (with tubes)
