deertrackdoctor
Bike / Product Year: 2019
Manufacturer: specialized
Model: Specialized Levo Comp XL
Asking Price: 3795
Location Jedburgh Scottish borders TD8 6JZ
Description For Sale is my Specialized Levo Comp 29 2019 Size XL
£3795 OVNO call 07966788494
Purchased Dec 2019 So has Specialized warranty until Dec2023
Only 414 Genuine Miles on Odemeter used but in good condition with a few minor cosmetic scrapes only.
Bike has Never been Chipped or Modified in any way
Supplied with all original receipt and manuals
Standard Specification as listed below with Camoflauge Decal which can be easily removed to reveal original yellow decals if preffered .
Based In Scottish Borders Region TD8 6JZ
Collection Only
To arrange to view or any questions please meesage and i shall reply ASAP
FRAME Specialized M5 Premium Aluminum, 29 Trail Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel
FORK RockShox Revelation Charger RC, 29" Boostâ„¢, 150mm of travel
REAR SHOCK RockShox Deluxe RT w/ custom air valve, 150mm of travel
FRONT HUB Specialized, sealed cartridge bearings, 15x110mm thru-axle, 28h
REAR HUB Specialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
SPOKES DT Swiss Industry
RIMS Roval Traverse 29, hookless alloy, 30mm inner width, tubeless ready
INNER TUBES Standard, Presta valve
FRONT TYRE Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
REAR TYRE Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
CRANKSET Praxis, 2D cold-forged alloy, custom offset, 165mm
CHAINRINGS 32T, custom steel
SHIFT LEVERS SRAM S700, single-click lever
REAR DERAILLEUR SRAM GX, long cage, 11-speed
CASSETTE SRAM PG-1130, 11-speed, 11-42t
CHAIN KMC X11ET, 11-speed w/ Missing Linkâ„¢
FRONT BRAKE SRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
REAR BRAKE SRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
HANDLEBARS Specialized Trail, 6061 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp
GRIPS Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
STEM Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise
SADDLE Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
SEATPOST X-Fusion Manic, 34.9mm, 125mm of travel (Small), 150mm of travel (M/XL)
SEAT BINDER Alloy, 38.6mm
MOTOR Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal
UI/REMOTE Specialized TCU, 10-LED state of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, handlebar remote with walk-assist
BATTERY Turbo M2-500, fully integrated w/ rock guard, 500Wh
CHARGER Custom charger, 42V4A w/ Rosenberger plug
WIRING HARNESS Custom Specialized wiring harness
PEDALS Specialized Dirt
