Sold 2019 Specialized Levo Comp: £4000
TankWizard83
Durham
Bike / Product Year: 2019
Manufacturer: Specialized
Model: Levo Comp
Asking Price: £4000
Location Durham, UK
Description
For sale is my Specialized Levo Comp in size large.
It is in great condition and in full working order.
Recently fitted new 2.1 motor and power cable by Infinity Cycles, this bike now qualifies for the 4 year warranty offered by Specialized ( 2 years and 9 months remaining).
New rear hub service also carried out.
100% battery health and the bike have covered 294 miles with the new motor.
I upgraded the stock forks for the amazing RockShox Lyric Ultimate Rc2 set at 160mm travel. These forks are one of the best on the market.
I have also fitted a brand new chain and cassette ready for the sale. I will include a new set of brake pads as the old ones still have life in them.
Please read below for the full spec and send me any questions you may have.
FRAME - Specialized M5 Premium Aluminum, 29 Trail Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel
FORK - RockShox Lyrik Ultimate RC2 , 29" Boostâ„¢, 160mm of travel
REAR SHOCK - RockShox Deluxe RT w/ custom air valve, 150mm of travel
FRONT HUB - Specialized, sealed cartridge bearings, 15x110mm thru-axle, 28h
REAR HUB - Specialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
SPOKES - DT Swiss Industry
RIMS - Roval Traverse 29, hookless alloy, 30mm inner width, tubeless ready
INNER TUBES - Set up tubless
FRONT TYRE - Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
REAR TYRE - Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
CRANKSET - Praxis, 2D cold-forged alloy, custom offset, 165mm
CHAINRINGS - 32T, custom steel
SHIFT LEVERS - SRAM S700, single-click lever
REAR DERAILLEUR - SRAM GX, long cage, 11-speed
CASSETTE - SRAM PG-1130, 11-speed, 11-42t
FRONT BRAKE - SRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
REAR BRAKE - SRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
HANDLEBARS - Specialized Trail, 6061 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp
GRIPS - Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
STEM - Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise
SADDLE - Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
SEATPOST - X-Fusion Manic, 34.9mm, 125mm of travel (Small), 150mm of travel (M/XL)
SEAT BINDER - Alloy, 38.6mm
MOTOR - Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal
UI/REMOTE - Specialized TCU, 10-LED state of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, handlebar remote with walk-assist
BATTERY - Turbo M2-500, fully integrated w/ rock guard, 500Wh
CHARGER - Custom charger, 42V4A w/ Rosenberger plug
WIRING HARNESS - Custom Specialized wiring harness
PEDALS- Not included.
TankWizard83
Durham
Does the extended warranty carry over to new owner?
Hi,
Yes the warranty is transferable as per this link.
I hope this answers your question.
Regards
Steve.
Wiltshire Warrior
563
228
Poole
crikey the frame warranty isn't transferable then and everything is 2 years from date of purchase. it doesn't say that you get another 2 years from the date of a warranty repairs, where did you get this info from?
So what was the original date of purchase please?
521K
