2019 levo
Paul willis
73
Wisbech
Switch on got red flashing bar at the top switched it of and on same happened then it whent out on its own rode it no prob stopped for cake started it again same thing happened then it went out on its own tried two batteries same happened with both could it be just cold
DS.
73
42
Devon
Might be TCU battery running low one of are 19 levos is throwing it up just depends what lights are flashing
Paul willis
73
Wisbech
Thanks that’s what it was red light flashed for about 30 seconds then went of and all blue ones ,what a job to change it what I did was push small tab it and tapped it on solid bench and it fell out
Burner
48
18
Manchester
Hi I have this aswel
When you say the tcu, do you mean the on/off switch has a battery in it and it needs replacing?
20,489
The "TCU" (Turbo Connect Unit) - in the top tube has it'sown integral 1620 battery which needs changing once in a while :
Levo Laland
273
236
Surrey UK
I know 3 people all with 2019 Levos where the TCU battery has needed replacing. If you own a 2019 Specialized bike you should order one as they appear to have 3 year lifespan. Most dealers don't even know the TCU battery is replaceable.
