Jake From State Farm
Im running a 2019 levo 170mm Lyrik at 20% sag / RS Delux at 30% , 27.5 F/R with 2.8 DHR2 and Cushcore+ F/R
I'm currently running the flip chip on high to compensate for the bottom bracket drop.
Question is..
If I want to run the flipchip in low will it be TOO slack with the 170mm? I can always go to 160mm cranks to avoid pedal strikes.
I fear it may slack out too much and make the front end wallow and wash which I've had problems with in the past.
So far it feels good but still does feel a bit flat in the geo even with the 170mm...
Question is..
