For Sale (BIKE) 2019 Fox CTD DPS Volume Spacers Tokens kit for Levo Comp 2019
Benson
Hampshire UK
Fox CTD/DPS Volume Spacers aftermarket equivalent to Fox PN 803-01-250 up to 0.8” for 9mm shaft. These are ideal for the Fox DPS shock in a 2019 Levo Comp (DKNW)
These volume spacers are made in the UK. They are 3d printed from a high quality chemical and oil resistant polymer - PETG, which is used for drinks bottles, chemical containers, fuel tanks etc. Spacers are PLA free.
Volume spacers will increase the spring curve of your rear shock making it stiffer at the end of the stroke. This is a great way to keep your shock nice and active at the start of the stoke as you can run lower pressures thereby decreasing breakaway friction and improving small bump compliance. The increased spring curve will help prevent progressing through the travel too quickly and the shock bottoming out.
Price is £12 including UK postage for all four.
This volume spacer kit includes 4 sizes:
Size 4 - Largest - 0.8in3 equivalent to Fox pn 233-00-353 (Cannot be fitted to older CTD Shocks)
Size 3 - 0.6in3 equivalent to Fox pn 233-00-352
Size 2 - 0.4in3 equivalent to Fox pn 233-00-351
Size 1 - 0.2in3 equivalent to Fox pn 233-00-350
