Levo Gen 2 1st Gen Levo Mullet Conversion
krisrayner
43
33
California
Just broken my front rim on my ‘17 Levo and considering replacing it with a 29er. Currently I’m running a 160mm fork, so I’m anticipating lowering it to 140-150. Anyone with experience doing the mullet conversion on a 1st Gen Levo? Impressions?
Swissrob
326
298
Switzerland
I have a 29x2.6 Assegai on my 2018 Levo and I like it. It is taking me some time to get used to it as the front is so stuck to the ground and I don't have the confidence to really load/use the front to it's full potential. Speed through root gardens has dramatically improved.
krisrayner
43
33
California
What fork and travel setting are you using? I wouldn’t want to slacken mine anymore than it is with the 160mm
krisrayner
43
33
California
Update-
Put on the 29” front wheel. Derby i40 in the front with Eddy Current 2.6. Left the fork at 160mm. Measurement between the two wheels seems like the front is about 10mm higher. Test ride to come and I might lower the fork 10mm to get back to where it was before the mullet-ization.
krisrayner
43
33
California
I have two variations of the same shock. When I bought the bike it can with a BikeYoke on it, so I was able to run a 190x51 DVO Topaz shock. Recently I found a good used identical DVO shock but with the Specialized mount for the stock yoke. It was too good a deal to pass up, $100. So basically I have a backup shock as well now.
Jono967
65
142
Victoria Australia
Thanks for that
Just one more question what type of yoke to I need to buy to run that shock
this is all new to me
krisrayner
43
33
California
Option 1: If you want to run a shock with a standard length (7.5"x2.0", 190mmX51mm) then you want this shock yoke that will let you do that.
Option 2: There are brands who make shocks in the Specialized size, (197x47.6), that works with the stock yoke. Fox and Rock Shox have ones, as does DVO ( which has become my preference due to adjustability) Topaz T3 Air Shock – DVO Suspension
Replacement shocks for the stock yoke are the same shocks that are used on the Stumpjumper of the same generation.
I trolled Pinkbike and came across the Specialized specific DVO shock. Deals are to be had if you take your time.
522K
