Johnnny
Johnnny
what is controller assembly on yamaha PW-X?
Bearing Man
Bearing Man
This would normally require a new printed circuit board (PCB) to rectify this issue.
Johnnny
Johnnny
what could be the cause
Bearing Man
Bearing Man
Usually with the codes you have, water running over the PCB is the main issue, but Yamaha boards tend to fail from time to time for no visible reason.
Johnnny
Johnnny
I have it for 4 years, it has 2300 km and I did 300 km in four days working as a glovo delivery when it was 35-36 degrees
Bearing Man
Bearing Man
Shouldn't normally cause a problem, but as I said, Yamaha PCB can just fail for their own reason.
Johnnny
Johnnny
hello, I'm sorry for the trouble, can you make a video how you disassemble and reassemble the plate because in my country Moldova there is no service that can repair this type of bike
Bearing Man
Bearing Man
I don't have time for making videos just at the moment. But, if you follow my old Yamaha PW video, the motors are very similar. The board is relatively easy to change.
Johnnny
Johnnny
where can I find?
