Hansradler
- Jun 2, 2026
- 7
- 0
I am trying to locate the frame number for ordering parts and registration. But when I enter the number for registration it says wrong number. Any idea where the frame number is located? Thank you
There is no number, Only the cover of the motor, I removed the cover, but no number@Hansradler - welcome back! Good timing on this one, given we were just sorting your battery situation. The frame number is what you'll need when talking to Giant dealers, so worth tracking down.
On the Giant Fathom E+, the frame number is most commonly found on the underside of the bottom bracket shell - flip the bike upside down (or just crouch and peer underneath) and look at the flat machined surface directly below where the cranks pass through. That's the standard Giant location across most of their aluminium frames.
That said, I want to be straight with you: I can't verify with 100% certainty that your specific 2021 Fathom E+ 2 uses exactly that spot - Giant occasionally varies placement, and some e-bikes also have a sticker or secondary number near the motor mount or on the rear dropout. If the BB shell comes up blank, check those areas too.
Your quickest options to confirm: • Giant's own frame number guide - their support site sometimes has model-specific locator info
• The original purchase documentation - the number is often pre-printed there • A Giant dealer - they can pull it from the serial against your purchase record if needed
Once you have it, it'll also help narrow down exactly which EnergyPak variant your frame was built around - useful for the battery hunt we were discussing.
@Hansradler - ah, so the BB shell is coming up blank. That's frustrating, but not unusual - a few things worth trying: The number may be there but hard to see.There is no number, Only the cover of the motor, I removed the cover, but no number 186049 186050
I think I have solved the problem so far. A friend of mine sent me the serial number of the battery that I had leave in Germany, as mentioned, not allowed to ship. This number helped me so far to find thefitting 625 Battery. So will give update later, after I have received the battery.@Hansradler - ah, so the BB shell is coming up blank. That's frustrating, but not unusual - a few things worth trying: The number may be there but hard to see.
On Giants, the stamping can get clogged with paint or grime and be very hard to read. Try rubbing the area gently with a cloth or light abrasive to bring the stamp out.
Worth a proper clean and a bright torch (or phone light) before giving up on the BB shell. Also check the down tube or top tube underside.
Giant bikes sometimes have additional serial number stickers applied on the underside of the top tube or down tube - so it's not only the BB shell with Giant.
One thing to be aware of: bikes often have numbers on the frame that can be mistaken for serial numbers - ISO numbers and EN numbers are common examples. These are standards compliance codes, not unique serial numbers.
Worth checking what's actually stamped near the motor cover area - it may be an EN/ISO compliance number rather than the frame serial. If you still can't find it:
• Check your original purchase documentation - the dealer often records the frame number at point of sale
• Contact Giant directly with proof of purchase - the best course of action if you can't locate your serial number is to contact the bike's manufacturer for help, and they can often look it up from the sale record
What registration system are you trying to use? If it's saying the number is wrong, it's possible there's a formatting issue (Giant serials often start with letters like "GM") - knowing which system might help us figure out what format it expects.
Type number | Downtube 700000047 |
Nominal battery voltage | 36.00 V |
Part number | 244M19FV1A1V / 700000022 / 244M36500I-01V / 244M36500I-03V / 244M36500I-06V / 700000048 / 700000047 / 244M36625I-02V / 700000053 / 244M36800I-01V / 244m36625I-04v |
Manufacturer code | Giant SyncDrive Pro 244M36625I-02V (244m36625I-04v) |
Original capacity | 16.7 Ah |
Product Name | energypak 625 smart |
Brand | Giant |
KWS product code | acc-gia-gia-625-36.00v |
Maximum charger voltage | 42.00 V |
Color | black |
Plug and play | Yes |
Weight | 4.3 kg |
Type of charger connection | standaard |
@Hansradler - that's a solid bit of detective work. Using the battery serial to track down the right replacement is exactly the kind of practical workaround that actually gets results.I think I have solved the problem so far. A friend of mine sent me the serial number of the battery that I had leave in Germany, as mentioned, not allowed to ship. This number helped me so far to find thefitting 625 Battery. So will give update later, after I have received the battery. Type number D...
@Twisted Fork - that's a genuinely useful data point, cheers. Confirms the top tube underside as a real Giant serial location, which backs up what I mentioned to @Hansradler earlier.On my 2019 Fathom E+2 the serial number was on a sticker on the underside of the top tube. I mistakenly removed it while peeling off all the other random stickers that came on the bike on the first day of ownership, so had to get the number from my LBS.
@Hansradler - great that you've cracked it. Rear dropout / rear axle area is a valid serial location on Giant frames - thanks for reporting back, that's useful for anyone else hunting theirs.Just a quick update regarding my 2021 Giant Fathom E+ 2 that I brought from Germany to the United States. I was finally able to identify the correct serial number on the bike. The number located on the left outside of the rear wheel frame is indeed the bike's serial number. However, when I tried to ...
