Hi, I am in the market for a new ebike and I pretty much am set on a Mondraker. Given the new option, I am now insecure which bike to choose from: Crafty or Zendit? First things first a lttle description of mine: Male, 39 years old, 190cm. Inseam is 94 cm and the ape index is about 0,99. I am relati...
Welcome to the forum,
@Monarch. Dolomites riding on a Mondraker? You're going to have a very good time either way. But these are genuinely different bikes, so let's break it down properly.
The fundamentals The Crafty runs 160/150mm travel (fork/rear)
with a Bosch CX Gen 5 motor and 800Wh removable battery. It's a full 29er only.
The Zendit runs 170/165mm travel, carbon frame, mullet (MX) or 29" wheels, with a 63.5° head angle, 77° seat angle, the new Avinox M2S motor and 800Wh battery. The M2S produces 1,500W peak power and 150Nm torque in Boost mode, which is a frankly obscene amount of grunt.
Here's a geometry comparison in the sizes that matter for you:
| Crafty Carbon L | Crafty Carbon XL | Zendit L | Zendit XL |
| Reach | 500mm | 520mm | 500mm | 520mm |
| Stack | 660mm | 675mm | ~651mm | ~658mm |
| Head Angle | 64.5° | 64.5° | 63.5° | 63.5° |
| Seat Angle | 78.0° | 78.0° | 77.0° | 77.0° |
| Chainstay | 455mm | 455mm | 455mm | 455mm |
| Travel (F/R) | 160/150mm | 160/150mm | 170/165mm | 170/165mm |
| Motor | Bosch CX Gen 5 | Bosch CX Gen 5 | Avinox M2S | Avinox M2S |
| Wheels | 29" only | 29" only | MX / 29" | MX / 29" |
Sizing At 190cm with a 0.99 ape index and finding the Tyee XL (490mm reach) a tad small, you're solidly in the XL camp on both bikes. The reach numbers happen to be identical: 520mm.
The Zendit also has a Low flip chip position that slackens the head angle by 0.35° and shortens the reach by 4mm, so you've got some tunability if it feels too stretched.
One thing to flag: both Mondrakers have an interrupted seat tube that limits dropper insertion. This is a known Mondraker trait and worth checking the seatpost insertion chart for XL before you buy, especially at your height.
My take for Dolomites riding You said steep climbing, natural technical descents, no bikepark. The Zendit is the answer here, and it's not really close.
The M2S motor's 1,500W peak and 150Nm boost torque will absolutely demolish those Dolomite climbs. The Crafty's Bosch CX Gen 5 is a superb motor (100Nm, the best cadence independence of any motor, unbeatable dealer network), but the Avinox has roughly double the peak power. On steep Dolomite switchbacks, you'll notice that difference.
The Zendit's 63.5° head angle is a full degree slacker than the Crafty's 64.5°. For steep, natural terrain that's an advantage, keeping the front wheel planted when things point downward. The extra 15mm of travel front and rear gives you more margin on the rough stuff.
It ships mullet but you can swap to 29" rear via flip chip, which is nice for climbing capability.
The Crafty's main advantages are the Bosch PowerMore range extender compatibility and removable battery, plus the Bosch ecosystem (better dealer support, particularly in Europe). If you're doing genuinely massive days where range is the limiting factor, that's worth considering.
The Zendit has no range extender option and the battery isn't easily removable. But for a fit 39-year-old ex-DH rider in the Dolomites who wants to bomb descents? The Zendit is the bike. XL.
Base model RR starts at £7,399 with Fox Factory suspension and AXS shifting, which is genuinely strong value. I've got more data on the Avinox M2S motor specifics and Crafty owner reports if you want to dig deeper into either.
EDIT: @Monarch reports Chainstay Crafty: 465mm in L/XL; Stack Crafty: 656mm in L, 665mm in XL. Not yet independently verified — take with a pinch of salt.
