Sparkomatic
Hi all!
Does anyone have experience replacing a bushing mounted shock with a bearing mounted one?
I've found a Fox Float DPX that should be a decent upgrade from the stock shock on my non-ebike ('21 Norco Fluid FS). The Fox shock uses a bearing mount rather than a bush though. From the limited info I've found this should fit the 8x30 mount on my linkage? The bearing mount should also be be a nice upgrade I believe? There does seem to be quite a bit of rotation at the linkage mount on this bike which is where the bearing will be as the shock is mounted upside down.
Thanks in advance!
Thanks in advance!
