Scford
Thanks for the advise, I’m running a zeb ultimate, charger 3. I’ve been trying to do 1 change at a time, just keeps feeling off so i keep tweaking. Definitely getting in my head about it, feel like im riding worse and worse, constantly thinking i don’t feel good on the bike so then translates into skipping more and more sections of trail from no confidence. Started comparing geo to my previous bikes and just leaning into maybe the bike is too bigI''m your size and I went with the RH2 knowing I was going to run full 29 and that would make it feel even longer, and it seemed long on paper to begin with to me. Anyway, that's not helpful unless you sell and buy a RH2.
For any tweaking don't forget to change one setting at a time and test. I can imagine in the frustration you're feeling making multiple changes and feeling lost as to what's working and not. Also, if you're like me and probably most people, don't get too in your head about how you're riding by messing with things like your body positioning, how you jumbo, etc. That can throw everything out of wack.
To me, I would guess someone's on too SMALL of a bike, not too big with what you're experiencing. Which makes me think it's more of a rear/front suspension set up and balance issue. Too fast rebound in the back, fork wallowing in the mid travel/too much sag will push you forward on jumps no matter how fast the fork rebound is. It's all speculation really. What fork are you running?
Set up wise, longer CS and -5 reach adjust is going to help F/R center and put you more in the middle of the wheels. The +14mm stack is only like .5 a degree.
