Gauss Guzzler
Yeah, I don't know if the larger Supernova plug fits thru the chainstay hole, I fed the raw wire thru from the other direction and then soldered in-situ.
Is the connector available in the US yet? I cant seem to find one.
Fanatik is the only company in N. America selling the SRAM cable and their pricing fluctuates from $96 to $220 on the rare occasions that they have cables in stock.
AXS Extension Cord - Eagle Transmission
The extension cord is an optional item to power the Transmission derailleur by the main system battery instead of a separate AXS battery. The extension cord interfaces to the derailleurs AXS battery port and is designed to be internally routed through the frame directly to the drive unit. The...www.fanatikbike.com
Or you can make your own for a little bit less:
"My" Sram Power cord
That connector fits my cable at least without any real issue. Red wire is -, black is + though.www.emtbforums.com
Yes it is. Had my shop install one for me 2 weeks ago. And it works really well especially since it can shift with no load on the systemIs the connector available in the US yet? I cant seem to find one.
Did they say how hard it was to install?Yes it is. Had my shop install one for me 2 weeks ago. And it works really well especially since it can shift with no load on the system
It did plug right into the motor but they did have to partially remove the rear triangle and drop the motor to route it through there properly
Shifting pod, t type chain, chainring and cassette are also necessarySo all I need is the extension cord and a new GX AXS T-type derailleur correct? Is there anything else?
I'm sure if you still have the cable housing that would be MUCH easier, mine was already pulled since had already switched to wireless. My LBS is very meticulous and like to make sure everything is perfect. So while you may not have to do anything with the triangle, they may have just to make it easier on themselvesI'm going be doing this conversion soon and have been able to find 2 YT videos showing how they did it. The drive unit has to be dropped of course but neither had to do anything with the rear triangle. The Chinese fellow made it look pretty easy. The other had a harder time getting the cable threaded through the chainstay but eventually got it. When I purchased the bike I had the shop install my X0 Transmission DR but had them leave the cable housing in the bike. Hoping to be able to use that to help fish the cable through.
The cheaper Amflow comes with t-type already. Why would you have to change the chain, chainring, and cassette?Shifting pod, t type chain, chainring and cassette are also necessary
Yes, you only need the derailleur, shifter, and extension cord.
Older Amflows came with Eagle drivetrains and you can use an Eagle AXS derailleur in that case for all the same functionality. Newer models have the flat top chains so you need the T-Type "transmission" derailleur.
You'd be crazy to mess with the rear triangle. It's trivially simple to shop-vac a piece of string thru the chainstay if needed to guide the cable thru. You don't need to remove the cranks or even the chain - just the 2 motor bolts. Best done upside down because the hardest part is getting the cables all folded neatly so they don't get pinched by the motor.
Lastly, I can't believe I have to say this, but Jesus, people - don't use masking tape or duct tape! Wow.
If you have some quality tape like kapton or even strapping tape that'd be ideal, but just regular old packing tape or even giftwrapping tape is perfectly fine. And you don't have to butt the cables right up against each other, you can leave a span of loose tape between them to make the corners easier to navigate.
All you'd need is a shifting pod, AXS T-type detailer, and extension cord, correct?
